Old 6th February 2008, 04:43 PM   #1
Lightbulb 6th Order Bandpass Subwoofer (rear & front chamber size?)
Hello !
I make subwoofer for my home theater system, it's only for low level LOW FREQ BASS presence.
The subwoofer is šno nameš DVC 8 inch (buy on ebay = china stuff)
I want make 6th Order Bandpass box only for hide the subwoofer.
I don't understand why the REAR and the FRONT chamber is not the same volume ? Anybody know why ?
Why don't take the vented box volume on each chamber ?
exemple: for this sub 18L volume vented why don't take this two times. One for FRONT and other for REAR ?
If the sound make 360 degree why the CHAMBER is not the same ?
Thanks in advance or your answer !!!
nicK
Old 6th February 2008, 05:38 PM   #2
MaVo is offline MaVo  Germany
you need the Thiele Small parameters of the driver. perhaps you can find them in the package, or on the internet.
http://en.wikipedia.org/wiki/Thiele_small
from there on, you need a subwoofer simulation program to simulate the response of your driver with a box.
just building one without knowing how big it needs to be will not work with a bandpass.
if you dont know the TS parameters, you will have to measure them or simply use a closed box as enclosure, since there the volume doesnt matter as much as with other enclosure designs.
Old 6th February 2008, 05:53 PM   #3
I have all information of this little subwoofer but I just don't understand why the REAR and FRONT chamber have not the same volume in 6th Order Bandpass ?
I create bandpass box only because my 7.1 system is hidden.
I don't view any woofer or tweeter in the room.
nicK
Old 6th February 2008, 07:53 PM   #4
Cro maniac's Avatar
Send a message via Skype™ to Cro maniac
One chamber in 6th order box acts just like a classic BR box, so it needs to be BIG for your sub to play low, while the other chamber acts as a lowpass filter and doesn't need to be big because it is tuned fairly high in frequency (as high as you want your sub to play).
You can make the second chamber as big as the first, but there is no purpose doing that because it won't bring you better or deeper bass, you'll just have bigger box and ridiculously short port on that chamber.
Old 7th February 2008, 12:58 AM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
Default Re: 6th Order Bandpass Subwoofer (rear & front chamber size?)
Well, if you put an equal enclosure on each side of the driver, one would produce sound always 180 degrees reversed from the other and you would have little or no sound at frequencies whose wavelength is longer than the distance between the two ports. Try it and see
The chambers of the system are different sizes and different tunings to make the sound blend better and cover a wider range.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 7th February 2008, 02:26 AM   #6
owdi is offline owdi  United States
owdi's Avatar
I recommend a 4th order bandpass instead of 6th. Much easier to design and tune without solid measurements, and has lower distortion than a regular vented box.
Dan
Old 7th February 2008, 02:43 AM   #7
Hello
The problem with 4th order is...............I HATE SEALED BOX
all the sub I had car or home in sealed box have ugly sound, when have big quick loud sound the distortion cone and other bizzard sound.
it's just my feeling !!!
I know many people say the best soundQ subwoofer is SEALED but for me NO
nicK
Old 7th February 2008, 03:27 AM   #8
For my 360 degree history, it's difficult to explain so here's a picture of my brain
For me the BEST AUDIO reproduction is :
* Class-A amplifier to reproduce all the 360 degree of wave.
* Flat cone speaker to reproduce almost the same 2 phase of 180 degree to create best 360 degree (I say almost because the driver don't have 1 motor by side) I understand me I'M NOT CRAZY
* For this reason I don't undertand why the 6th order bandpass doesn't have the same box in her 2 chamber
Thanks !!!
nicK
Old 7th February 2008, 12:33 PM   #9
Ron E's Avatar
I think you should build it and find out. Easier would be to model it with software and see what happens.
Old 7th February 2008, 01:04 PM   #10
For the moment I use SPEAKER BOX LITE but this software is not very great because I can't play with the size of the box and see the result.
Do you know a good software for subwoofer ?
Thanks !
nicK
WinISD pro to simulate 6th order bandpass subwoofer christophorus Subwoofers 14 13th September 2006 01:58 PM
front loaded bass horn without rear compression chamber? paulspencer Subwoofers 9 28th October 2005 05:53 PM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 10:29 PM
6th order bandpass subwoofer Ilianh Subwoofers 50 25th January 2003 02:40 AM
the isobarik 6th order bandpass transmission line folded horn subwoofer idea Yoda Subwoofers 3 24th October 2001 04:00 PM
Page generated in 0.11743 seconds (79.03% PHP - 20.97% MySQL) with 11 queries
