#11 | |
The woofer outputs the same signal on its front and on its back. If these are summed as is then you will have no sound - they will simply cancel out. The same happens if you use any form of waveguides or resonators or whatever in front and on the back of the driver. If these are equal then the output is again nulled out due to the fact that you feed both of these contraptions with the same signal but 180 degrees out of phase. It is getting interesting as soon as those resonators are tuned differently. Not only do you load the driver over a large bandwitdh (whatever large means) - the difference of the inherent natural phase-shift of these resonators adds another 180 degrees, helping to add the SPLs of the front and back efficiently. Regards Charles |
#12 |
Try downloading winISD for modelling.
Rob. |
#13 |
Hi nick
Two ports are difficult to tune it. I think you would like it when it works for your HT. I had ever built it(8"). The spl is highest. To be careful!! The cone has a good sound (POP).I know that time. Oh wow it is funny. regards |
| WinISD pro to simulate 6th order bandpass subwoofer | christophorus | Subwoofers | 14 | 13th September 2006 12:58 PM |
| front loaded bass horn without rear compression chamber? | paulspencer | Subwoofers | 9 | 28th October 2005 04:53 PM |
| searching software to switch front speakers to rear and rear to front!-dolby surround | MCM | Everything Else | 6 | 6th February 2004 09:29 PM |
| 6th order bandpass subwoofer | Ilianh | Subwoofers | 50 | 25th January 2003 01:40 AM |
| the isobarik 6th order bandpass transmission line folded horn subwoofer idea | Yoda | Subwoofers | 3 | 24th October 2001 03:00 PM |
| Page generated in 0.07515 seconds (71.78% PHP - 28.22% MySQL) with 11 queries |
