Old 30th January 2008, 11:52 AM   #1
Asdonk is offline Asdonk  Netherlands
Default SVS pb10 cloned
I have laid my hands on a SVS PB10nsd woofer and the 300 Watts BASH amp
I also have found someone who has measered the TS parameters
some further info is the vent is about 34 cm long and 3 inch
in diameter
some calculations give a netto volume off 62 to 64 liters
someone ever cloned or rebuild this subwoofer, it will only be used for movies
Ralf
Old 31st January 2008, 07:13 AM   #2
cph2000 is offline cph2000  Denmark
interesting woofer ! Could you post T&S numbers and maybe how you got your hands on it (I take it that it did not fall off the back of a truck ) ?
Old 31st January 2008, 08:01 AM   #3
no it did not fall off the back of a truck
the woofer and amp where sold by the former dealer over here in Europe, now you have to order through L Sound
Ralf
Old 5th February 2008, 11:47 AM   #4
the measured T&S parameters are
Qts 0,35
Fs 27,4 hz
Vas 60 l
Re 3,3 ohm
BL 13,42
Le 1,32
Sd 310
X max 16 mm
Pe 300 W
winSD gives a -4 db at 24 hz, as the BASH plateamp has a build in boost, 20 hz must be possible
Ralf
Old 5th February 2008, 04:49 PM   #5
GM is offline GM  United States
GM's Avatar
Originally posted by Asdonk
the measured T&S parameters are........
Sorry, but the specs don't add up. with a 13.42 BL a Qes around 0.24 is required, so no way Qts = 0.35 or vice versa. Since Vas is the hardest to properly measure, maybe this is what's screwing up the numbers.
Regardless, please post Qes, Qms too.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th February 2008, 04:59 PM   #6
Qes 0,37
Qms 6,28
Qts 0,35
these are the measured T/S
Ralf
Old 5th February 2008, 06:24 PM   #7
GM's Avatar
OK, thanks, but it still doesn't mean that Vas isn't wrong as BL now calcs around 10.88, which has a big effect on cab Vb.
Anyway, based on these specs a max BW alignment will be around 0.707*Fs with a ~ Vb = Vas EBS alignment, but due to the low Vas the vent will be excessively long, so a mass loaded reverse tapered TL (ML-TQWT) makes more sense to me. Corner loaded it should be solid into the teens, though its low Pe will keep it from getting to DD/DTS reference level if that's a performance goal.
Now if you can 'afford' a larger, ~81+ " tall cab and the T/S specs are close, a tapped horn sims an eyeball flattening ~125 dB with only ~140 W, but the trade-off is it's ~280.64 L + all the panel thicknesses, though if it can be laid down along a wall to fire into the corner it can be fairly small in cross section with only one bend 122+" long and of course more folds can be used to reduce its height if taking up a larger floorspace isn't a major issue:
GM
Old 14th October 2008, 03:58 PM   #8
no warranty on seperate amp panel bought from Europian SVS
dealer
here goes the project, as the Pb10 amp panel is not working at all
just about 10 months old
I contacted L Sound and this is what they answered today :
I just got a message from SVS now. I just wanted to check if M-Pro had a different sales policy since we do not sell separate SVS parts to DIY projects I am afraid. Warranty doesn’t count on separate parts and M-Pro shouldn’t have sold you these parts. L-Sound do not sell any DIY parts to customers either. I am very sorry about this.
Please let me know if there are anything I can help you with but we can’t give you a new amplifier since there are no warranty on the amp plate itself. The amplifiers which all SVS dealers have are for replacements only when a customer have bought a whole subwoofer.
Jan
Ralf
Cloned my second MT2!! skyraider Instruments and Amps 16 19th August 2011 03:42 AM
Arc Vt-60 Cloned :-) ANADIGIT Tubes / Valves 29 21st December 2010 12:51 PM
Has anyone cloned a MERLIN TSM? parhelia Multi-Way 3 4th July 2007 11:04 AM
Cloned Linn pete.a Analogue Source 9 20th June 2005 01:24 PM
Page generated in 0.09038 seconds (80.33% PHP - 19.67% MySQL) with 11 queries
