Kef PSW2000 Sub schematic required
Old 16th September 2010, 10:23 AM   #61
Hoodlum77 is offline Hoodlum77
I have KEF PSW 2000 sub wich have died on me.
The green light goes on, but that's all. No sound when touching the cable.
I opened the sub and read the 6 pages of this post.
I am no electronic expert, so i was hoping for some help.
Looks like R123,R119,R122 and R118 are leaking. I wil replace thes with the same values
R143 anR144 are also broken as it looks. Will replace these with 5W as suggested by Roar.
"Q18, 19 are to be replaced by BD139,140"? My sub has been repaired by KEf 4 years back. As you can see there are already on the heatsink, do I still need to replace this? if yes what part do i need.
"C42,43, replace with PP caps" what are PP caps?
"Relay are to be replaced with Omron G5LE1-24"this is the blue box, right?
So i miss anything or should i be good to go.
If there are any dutch people here who already ordered these parts, could you let me know where you ordered?
Old 4th December 2010, 12:02 AM   #62
nat76 is offline nat76
My sub are dead. Green light, but no sound.
Could someone send me the schematic? Please send it to nat@vianett.no.
Many thanks. Nat
Old 4th December 2010, 03:42 PM   #63
fandersen is offline fandersen  Canada
Done.
Also look at KEF Repairs. Lots of good information there.
Flemming
Old 22nd January 2011, 01:41 PM   #64
Bas Horneman is online now Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
My relay started chattering. I replaced c52 et voila!
To be sure I also kept c52's legs a little longer so that I could keep it further away from the warm resistors. See picture.
If you can see the speaker cone move...it's not hifi.
Old 16th May 2011, 11:05 AM   #65
killie99 is offline killie99
Default PSW200 Schematics
Anyone able to send me schematics for the PSW2000? The link posted earlier in this thread appears to be dead.
Email to killie99 at live dot co dot uk
thanks.
Old 17th May 2011, 04:22 PM   #66
thanks.
Done!
Flemming
Old 17th July 2011, 11:15 PM   #67
wayward91 is offline wayward91
Im about to put together the things I need to fix this but im starting to think theres no point. they seem to have a fault with pretty much every part on the power amp board. I got given one and the most obvious things are that q19 and q17 have failed / exploded . im half tempted to run it with an external amp rarther than have another problem arise in the future.
cheers for everybodys input.
this is a(/another) link to a service manual ......still not 100% on the first page of specs ?
http://members.chello.nl/b.kalle/kef...e%20manual.pdf
Old 19th March 2013, 11:48 PM   #68
ralfm22 is offline ralfm22
Dear all,
can anybody help me with a circuit diagram of the PSW2000 with der circuit/pcb version from June 12 2002? Every manual I found was different. Thanks
Old 5th October 2016, 10:20 PM   #69
pdlemen is offline pdlemen  United States
I know this is an old thread but this might help. If your sub has an intermittent thump with shut down after you have done any work to the the amp board, look for a broken trace on cement resistor R144. The trace gets broken when that resistor is knocked against the bottom of the pre-amp board when you are trying to get the amp board back down onto the heat sink.
Old 14th November 2016, 08:40 PM   #70
dizzu is offline dizzu
I have just received a faulty KEF psw 2010. The problem is that it works good for the first 10-15 seconds and then the volume goes down to an intermittent crack/pop which is very low sometimes. I tried bypassing the relay, replacing C52, C68, C59 and C60. All resistors and transistors tested and look fine. Any ideas please?
Kef PSW2000 Sub schematic requiredHide this!Advertise here!
Linn Intek Schematic required burbeck Solid State 49 3rd March 2015 12:24 PM
Schematic for Klipsch Sub 10 Required. lubbie Subwoofers 1 5th June 2009 07:14 PM
sony FH-B711 schematic required. prashbh Everything Else 0 7th March 2009 03:05 PM
c audio st 600 schematic required..... fabiodord Solid State 0 27th February 2009 04:05 PM
Marantz PM 440 and PM 351 Schematic required Krokotam_ Solid State 0 22nd October 2008 07:36 AM
