New Home Theatre Sub
Old 6th December 2007, 03:32 AM   #1
dark_avenger is offline dark_avenger  Australia
Default New Home Theatre Sub
hey everyone, i'm looking to build a new powered sub for my 5.1 system. at the momment the woofer i'm using bottems out at about 40-50Hz. I want to build something capable of 20Hz flat if possible/fesable.
The amp im thinking of using is this one
http://www.peavey.com/products/brows...item/116310/PV(R)%20900.cfm
Can deliver 600w into 4Ohm in bridged mode with built in 150Hz crossover.
any suggests on driver/box design and amp would be greatly apreciated.
David
Old 10th December 2007, 01:43 AM   #2
i'm thinking the 15" version of this sub
http://www.kicker.uk.com/compvx.html
Specs say down to 18Hz how big a box and what sort of design would the box have to have in order to get that low?
Old 16th December 2007, 09:28 PM   #3
GM is offline GM  United States
GM's Avatar
Greets!
With no T/S specs, no way to figure it out.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd December 2007, 04:27 PM   #4
hooha is offline hooha  Canada
hooha's Avatar
Those units are basically fart drivers. Certainly not something you would classify as producing quality output.
As GM mentioned, no T/S parameters either.
Best,
Mark
Breaking speed records - http://www.mach5audio.com
Old 24th December 2007, 04:46 AM   #5
dangus is offline dangus  Canada
There are T-S parameters in the pdf spec sheet:
For the CVX15:
Fs = 21.5 Hz
Qts = 0.304
Vas = 7.3 cubic feet
2 or 4 ohm dual coils
I threw those parameters into Perfect Box, and it suggests a vented cabinet 3.6 cubic feet for an F3 of 29 Hz. Not at all bad for a home sub.
But, there's probably some other driver that's better value for money, unless you can get a special deal on this driver.
Old 24th December 2007, 10:01 PM   #6
auplater is offline auplater  United States
auplater's Avatar
Default farts here?? don't think so...
Best,
Mark
dunno 'bout that... I built these 8 ft^3 with comps and they reproduce into the mid 'teens (with room gain) @ 110dB in a 15,000 ft^3 room, designed as ebs... priced right too @ ~$40/driver and that's with the 12" drivers... and these are just the comp drivers.
Wife calls the couch the "vibrochair" seeing as on most hometheater material, the couch actually levitates when strong IMPACTS are reproduced...
"I've forgotten more than I care to remember" The Last Conspirators
Old 25th December 2007, 04:48 AM   #7
GM's Avatar
Default Re: New Home Theatre Sub
Greets!
?? Not being into car audio beyond despising all the inconsiderate a$$holes driving around with their one note rolling boomboxes drowning out my tunes, I'm not sure what this means or what about its construction makes it one, so don't know what kind of alignment (if any) can deal with it.
GM
Old 25th December 2007, 05:02 AM   #8
GM's Avatar
Greets!
If these specs are reasonably accurate a well damped Vb = Vas, Fb = Fs (or a bit lower) TWQT could be pretty good in a HT app, especially if corner loaded. This slightly larger (~246.2 L) tapped pipe (TL) might be even better, though not knowing its excursion specs this peak SPL may just be a 'pipe dream' if not corner loaded and there's not enough room gain to help it below ~32 Hz. It should still pound pretty good if not though and it doesn't have an obvious 'gas' problem to mar its performance.
GM
Old 27th December 2007, 09:48 PM   #9
thanks for the advice, i'm abit new with speaker design. i'll have a look round and try to find a more value for money driver. i like the pipe design i'll have a look into that. thanks!
Old 28th December 2007, 10:55 PM   #10
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
I built a sealed box using the earlier Comp VR, it's a huge box, about 155 litres and stuffed to make it seem larger.
The problem seems to be a very peaky output at around 120 Hz so I stopped using it in my cheap home theatre setup ( it is currently sitting in my shed unused)
Come around and listen before you make a decision, E-mail me
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
New Home Theatre SubHide this!Advertise here!
Help with DIY home theatre switching box gto127 Digital Source 0 6th April 2008 05:15 PM
DIY Home Theatre luckybob Multi-Way 4 25th May 2006 06:19 AM
Home Theatre bhg41088 Multi-Way 4 16th August 2004 01:32 PM
Copyright ©1999-2017 diyAudio
