Old 4th December 2007, 02:15 AM   #1
Default Triska, STF-1 HSU or 8" Orb sub
Hi All,
I've been thinking about the Orb 2.1 speaker system:
http://www.orbaudio.com/index.asp?Pa...PROD&ProdID=16
for my living room to replace the small set of Sony bookshelf speakers I currently use:
http://www.audioreview.com/cat/speak...3_1594crx.aspx
As of right now, I only listen to music, but I will eventually want to use it for HT. I should specify that I most definately don't want to rock the house (condo), I just want to fill in some lows.
I spoke with an Orb rep. and he claimed their 8" subwoofer, which adds $310, is better then anything available for less then ~$700. So, I'm wondering if anyone has any experience with their sub and if so how do you think it would compare to the STF-1 HSU:
http://www.hsuresearch.com/products/stf-1.html
which I've seen recommended a lot, and how might it compare to a DIY project like the Triska from PartsExpress:
http://www.partsexpress.com/projects...aSub/index.cfm
Also, how do you think the Triska would compare to the STF-1, or the X-sub from av123? Am I really going to be able to build something superior to what I can get off the shelf?
Thanks in advance for any opinions you are willing to share!
-mark
Old 4th December 2007, 10:24 PM   #2
Default a single question
some wise person once suggested that a poster only ask one question at a time. I probably should have heeded this advice.
How do you think the DIY Triska would compare to an off the shelf model like the STF-1?
Old 20th December 2007, 07:04 AM   #3
HIPCHECK's Avatar
The triska sub is a very nice design. add a plate amp to the DVC 8 and you have about anything you can buy @ the best Buys and whatnot. would trump any of the Home Theatre in a box systems!
I have one built, and have run if off a lm3886 gainclone just to test. I have a large living room with 12 ft arch ceilings, and the triska played very well when pushed closer to the corner.
If you were going to DIY its a very easy project, make a box anywhere close to a cube or so, and add a little weight to the passives.
Buy the 70watt amp from Parts Express and you would be far better off than the HSU product, They make great stuff , but DIY only cost you parts really! $60.00 amp $50 for the passive/sub and your set!
good luck with your choice!
I wouldnt mind selling mine (used under 30 mins) pm/email if your interested
steve
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Another Triska Sub Jim Shearer Subwoofers 3 8th August 2008 10:58 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 01:09 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.08289 seconds (71.45% PHP - 28.55% MySQL) with 10 queries
