Shadow SD12 0V9
Greetings,
I am having a pair of the Shadow SD12 0V9 cabinets built. I was wondering if I could use these drivers from Parts Express #295-460, would work or not in the cabinets. I ask this only because I already have the drivers mentioned from Parts Express already and haven't ordered the SD12's from Creative Sounds Solutions yet. Sincerely, Cambe:cool: |
Greets!
Specs indicates it may be a bit under-damped, but nothing some extra stuffing can't handle if need be. GM |
Hello GM,
where and how should the damping be placed? I want to thank you also for helping me figure out the TL using the same PE driver. Sincerely, Cambe :cool: |
Greets!
For this style cab, I'd line the bottom, back, and one side to start and the other side and/or baffle next, then start doubling up if need be. You're welcome! Did it perform well or are you trying this new cab because it doesn't? GM |
Hello,
GM, the TL design you helped me with, is still on the drawing board. I planned to send you a copy of the drawing for the TL to look over before building it. Just have not gotten around to it yet. Cambe :cool: |
| All times are GMT. The time now is 08:31 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
