diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   optimal speaker for closed cabinet? (http://www.diyaudio.com/forums/subwoofers/112962-optimal-speaker-closed-cabinet.html)
Jan Volkering 2nd December 2007 06:54 PM
I am looking which Thiele Small Parameters to look for if I want to use a woofer in an as small as possible closed cabinet.
I am using back EMF to servo the speaker so passive roll off in not critical. A low as possible Q is important as I am driving with a current amp.
Any suggestions here?
buggsson 2nd December 2007 07:22 PM
You will need a Qes that is at least double the Fs to have an EBP of less than 50, which is preferrable.
Qts between 0.2 to 0.5.
Resources saved on this page: MySQL 18.75%
