Old 26th November 2007, 05:38 AM   #1
Mendoza is offline Mendoza  Australia
Default Looking for a 1ohm 1200w ac amp for subwoofers
Hi all,
Sorry for putting this in the wrong place, im not sure what sort of amp I'm looking for.
Im wondering if anyone knows of a solution to my problem. I have bought 8 10" subwoofers in a sealed box all wired for 1ohm, it was originally used in a car but im wanting to use it inside. It was powered by a 1200 monoblock in the car , which I dont have.
The woofers are the jaycar response series if that matters. I tried searching for 1ohm and 1200w but most of what comes back is car related, or seems to be not what im after.
Any suggestions?
Old 26th November 2007, 06:08 AM   #2
I would recommend rewiring it to 2x 2ohm and then using some pro amps like the Behringer EP2500
You might also need to eq or redesign the box for a better low end roll off, most car setups use too small of a box.
Old 26th November 2007, 06:17 AM   #3
TWOJZ is offline TWOJZ  Australia
Account Disabled
so you're the guy that bought those off ebay!
the boxes they are in do not suit the woofers at all.
the setup only did something like 142dBs, it should have been doing 150 if it had a proper box.
I think your first step should be to make a ported box, even an isobaric one
Old 26th November 2007, 07:30 AM   #4
Thanks for the replys
Thanks for the link, im watching one on ebay now.
Would any of the kits around here be suitable? I know that amp is cheap for what it is but im trying to be even cheaper lol.
The box it's in is quite large, as it was used in tray of a ute it's 8 cubic feet with 4 chambers (2 subs per chamber). Id really like to not have to lose the box as it seems well made, It also has those banana plugs on cables leading out and they are bigger than the ones that go on my car battery.lol
Yep, it was a real bargain at $121, just a long drive
I was originally thinking of splitting it up (a friend wants 4 for a bass amp) but im keen to see how it goes as is, and 140db should be annoying enough for my neighbors and house mates .
I also read on probably the same forum that he was playing music, I dont know if that makes a difference, I dont know very much about this sort of thing.
Thanks again
Old 26th November 2007, 08:06 AM   #5
Account Disabled
playing music could make a few dB difference, it could make no difference...
realistically, it was as loud as a decent single 12inch sub in the vehicle it was in, so chances are, thats what it would be comparable to in a large room...
Old 27th November 2007, 04:56 AM   #6
Cheers TWOJZ
I'll get some better measures of the chambers in the box, to get a better figure of it's capicity. Maybe I can add a port??? you can probably tell I dont really want to change the box
Also I just realised it was running off a 1500w soundstream amp when it made 141.5db not a 1200w
Old 27th November 2007, 05:51 AM   #7
Account Disabled
get the dimensions/volume of the box, if its a single chamber, you may be able to turn it into an isobaric ported box
could my boss gt6 blow up a 1200w beringer PA head???? billywhizz Instruments and Amps 11 19th April 2009 08:26 PM
JBL LC-1200W Xmax and effective diameter mtf545 Subwoofers 0 12th December 2008 12:33 AM
C.A.S Optimum II , 1200w power amp... pat allen Solid State 21 24th January 2007 04:10 PM
WTB: 1ohm 5 w Mills resistors paulyang Swap Meet 3 8th December 2005 06:59 AM
1200w+ Amp Shootout March 27-28 Bink Solid State 3 9th February 2004 07:47 AM
Page generated in 0.10454 seconds (77.11% PHP - 22.89% MySQL) with 10 queries
