Old 14th November 2007, 04:28 PM   #1
Default 12'' Subwoofer box design
Hello!
I have one 12'' driver....so i wont to use it for sub.
So if someone can help me with drawnings (design) of box for it....I was thinking on some vented box system......
regards,
Marin
Marin
Old 14th November 2007, 05:43 PM   #2
We need a lot more information, like the brand and model plus the Thiele Small (T/S) parameters...
Old 14th November 2007, 06:56 PM   #3
Eminence Delta 12-B
Resonant Frequency (fs) 58Hz
DC Resistance (Re) 11.4
Coil Inductance (Le) 0.77mH
Mechanical Q (Qms) 7.04
Electromagnetic Q (Qes) 0.52
Total Q (Qts) 0.48
Compliance Equivalent Volume (Vas) 87 liters / 3.1 cu. ft.
Peak Diaphragm Displacement Volume (Vd) 140cc
Mechanical Compliance of Suspension (Cms) 0.23mm/N
BL Product (BL) 16.0 T-M
Diaphram Mass inc. Airload (Mms) 32 grams
Efficiency Bandwidth Product (EBP) 112
Maximum Linear Excursion (Xmax) 2.7mm
Surface Area of Cone (Sd) 519.5 cm2
Maximum Mechanical Limit (Xlim) 9.0mm
Marin
Old 14th November 2007, 07:09 PM   #4
Nanook is offline Nanook  Canada
Nanook's Avatar
Default how big do you want the box?
cause that usually is a limit...
ok, the Delta isn't really a subwoofer. do you already own it? If not please look for a true sub, with a lower fs, and a smaller Vas
stew -"A sane man in an insane world appears insane."
Old 14th November 2007, 08:44 PM   #5
Yap....
I was thinking to some data abou sub constructing....nothing special, just because I have speaker to put it in something :-)
Also I have one dynacord 12'', but don't have data except 8Ohm 250W.
And coil dia si (funny ) like in delta 2,5''
Marin
Help in subwoofer design. pmkierst Subwoofers 25 2nd February 2009 07:50 PM
Subwoofer Box design ali_moinuddin Subwoofers 1 28th June 2008 03:52 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Subwoofer design plan .. Is this O.K? Lach O'Sullivan Subwoofers 4 16th September 2003 01:39 AM
subwoofer design problem pkgum Subwoofers 90 30th December 2001 12:12 AM
Page generated in 0.09229 seconds (73.64% PHP - 26.36% MySQL) with 10 queries
