Old 11th November 2007, 04:58 AM   #1
mhtplsh is offline mhtplsh  India
Default passive radiator testing
How to test passive radiator?
I saw the following data of commercial passive radiator.
How they hv measured it?
Old 11th November 2007, 01:00 PM   #2
Here is the data
Old 11th November 2007, 02:49 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
I think I have posted a procedure here.
Yep:
Passive Radiator measurements?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 11th November 2007, 02:55 PM   #4
Thank u very much Ron E.
I will use ur method.
Old 11th November 2007, 06:45 PM   #5
I refer to Brians's website http://www.diysubwoofers.org. about
Passive Radiator.
It is mentioned :
To measure the resonance frequency of the passive radiator, install it
in a free-air baffle (e.g. the box it's going in, without the driver
in place), then hold a driver, driven by a sine wave generator, as
close as possible to the passive radiator, then vary the frequency. At
the passive radiator's resonance frequency, you should see the
greatest peak to peak excursion of the passive radiator.
I understand that free air baffle means just one sheet of any plywood
with hole to mount driver.
Is this correct.
Old 11th November 2007, 07:22 PM   #6
Ron E's Avatar
Originally posted by mhtplsh
Is this correct.
It could work, not sure how apparent the PR motion would be, though. If you did the test twice (once after adding mass enough to shift Fp by 30% or so) you could also calculate Vap, theoretically...
If you are daunted by the testing, simply calculate the mass of air in a port with the same diameter (with the same box volume and tuning you want) and try to make sure that the PR weighs that much (in total) should suffice.
Old 14th November 2007, 07:13 AM   #7
"Here is the data"
That's a very low Qms, which will attenuate output significantly.
Noah
passive radiator testing? jaya000 Subwoofers 1 6th May 2009 05:22 PM
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
Page generated in 0.09159 seconds (72.41% PHP - 27.59% MySQL) with 11 queries
