Old 6th November 2007, 07:41 PM   #1
hewlew1 is offline hewlew1  United States
Default Box dimensions
I have some older Cerwin Vega woofers that I would like to build a box for. Cerwin Vega does not have the parameters for these older woofers. The original enclosure was approx 4.97 cubic feet with two 4 inch ports 9.5 inches long. I would like to construct 1 box with both woofers wired in series in it with no internal divider . My question is would I double the volume to 9.94 cubic feet and would I use four 4 inch ports 9,5 inches long , or does this change some dimensions when more than 1 driver are in the same enclosure. any help you can offer is appreciated. Harry
Old 6th November 2007, 11:07 PM   #2
Yep,that will work fine,or you could add the divider,which would add some more bracing to the box.
ESL dimensions Few Planars & Exotics 2 24th February 2008 05:47 PM
Some questions on ESL dimensions jnb Planars & Exotics 37 17th July 2007 08:22 AM
atlas 15 dimensions William-L Subwoofers 4 10th May 2005 06:48 AM
Casing dimensions Mlaen Solid State 1 20th February 2005 06:32 PM
Box dimensions Vivek Multi-Way 10 16th September 2001 08:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
