I am putting new 15" raw speakers in existing cabinets to run as subs for my band's PA system. The issue I am having is I can only find 8 ohm speakers, and I want 4 ohm speakers.
I am no expert at ohm loads, but I have always been told there is no way to lower the ohm load, only increase it correct? So if I buy two 8 ohm speakers and run them bridged out of a QSC 2450, I will be at an 8 ohm load and restricted to 8 ohm wattage output correct? Is there any way around this other than find (and pay for) 4 ohm speakers? The second question is with the 8 ohm speakers be effective with the QSC 2450?
Phoenix |
#2 |
Two 8 ohm speakers connected in parallell will result in a 4 ohm load.
"In a world gone mad, only a lunatic is truly insane..." - H.J.S. |
#3 |
Speakerholic
Hi KP,
Not sure where you picked up that little tidbit but Lord H is correct. Two 8 ohm in parallel results in a 4 ohm load. Two 8 ohm in series is a 16 ohm load. |
#4 |
Maybe consider running them in parallel as the others have suggested, so make the subs a mono channel and run them from the bridged output of the amp.
Also, take into consideration that the new speakers might not behave as the old ones did in that cabinet, given that it may have been tuned to work well with the old drivers. |
| A pondering question on subs | skooter | Car Audio | 16 | 27th September 2008 07:01 PM |
| Everything but the subs (simple newb question) | bigron | Car Audio | 10 | 19th December 2007 07:09 AM |
| Should I build a home subwoofer system with two 15" MTX Black Golds (car subs)? | dan50 | Subwoofers | 1 | 13th September 2007 02:47 AM |
| question for those using subs with 2 channel stereo | Jim85IROC | Subwoofers | 15 | 26th March 2004 02:38 PM |
| Page generated in 0.08497 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
