Old 8th November 2007, 10:53 AM   #11
djk is offline djk
djk's Avatar
This is the way I build my manifold boxes, not that much wasted space.
With a pair of 15s it's only about 1 cu ft, the net interior volume is on the order of 8 cu ft, port is tuned to 31hz (low B on a five-string bass).
Candidates for the Darwin Award should not read this author.
Old 11th December 2007, 06:18 AM   #12
Default Just about ready
Been ocupied by other things and my job
but now Im ready to build these babies
Im Going to be using Beyma 18G50 Speakers
here are the parameters:
Brand Beyma
Model 18 G50
Description Die cast aluminium basket. Paper cone. Plasticised cloth surround. Edgewound alum. flat wire voicce coil.
Range / type woofer
Typical use PA
Recomended enclosure Box size 80 / 200 Liters
Series PRO LF
Manufacturer Beyma
Order nr
Production status Active 2003
Nom. diamerer [inch] 18
Vas [Liters] 212
Qts 0,325
Qes 0,334
Qms 12,05
Fs [Hz] 40
Sensitivity [dB] 98
Max Power [W] 800
Power definition W AES
Lower freq [Hz] 25
Upper freq [Hz] 1500
Rec. Filter freq [Hz]
xmax [mm] 9
Moving mass [g] 170
Disp area [m2] 0,132
Disp Vol [cm3] 1,18
xdamage [mm] 40
Air gap [mm] 11
Coil height [mm] 25
Coil diameter [mm] 114
Cms [mm/N] 93
Rms [N*s/m] 3,54
Magnet weight [gr]
Magnet height [mm]
Magnet diameter [mm]
Magnet material - Ferrite
Re [ohm] 6,1
Z [ohm] 8
L [mH] 2
Bl [Tm] 28,8
Magnetic flux [Wb]
Flux density [T]
Outer diam. [mm] 460
Bolt circle [mm] 438
Nr of bolts [Nr]
Cutout [mm] 415
Weight [Kg] 14
Height [mm]
Depth [mm] 210
Driver volume [Liters] 13
Frequency SPL / Z
would these make good drivers for this enclosure?
Could someone please give me the dimensions off all
the boards needed to build this enclosure? (I find the plans confusing)
Thanks In Advance.
Old 12th December 2007, 08:59 AM   #13
Default Pic 1
pic1
Old 12th December 2007, 09:01 AM   #14
Default pic2
pic2
Old 12th December 2007, 09:02 AM   #15
Default Pic3
Pic3
Old 12th December 2007, 09:06 AM   #16
Default Now the Problem
When I Try cal culate the panel that I have shaded red in the attached pic
I get 572mm - 240 -240
wich gives me 92mm
Old 12th December 2007, 04:05 PM   #17
Send a message via AIM to TwisterZ
You left out the thickness of the 4 pieces of wood, 92 is to big.
Old 12th December 2007, 07:40 PM   #18
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI, The manifold and the suggested Beyma 18 G50 drivers using the layout of djk:s posted picture (post #11) simulated in a 310 Liter (red color plots) ported box, drivers on the front baffle, picture 1(2) to 2(2).
Using the same box but reducing the internal volume to 250 L (black colour plots) where the volume occupied by the manifold and drivers is arbitrarily set to be a loss of 60 L.
At last: A probable impact on the front side driver output from the slot and baffle load, marked with blue colour and blue plot using a separate simulation from MJK: s BLH_Sections_3_21_07[1] program sheet.
b
1(2)
Old 12th December 2007, 07:41 PM   #19
2(2)
Old 13th December 2007, 04:44 AM   #20
Thanks 4 the reply bjono
k twister
so that will be 572mm - ( (18x4) + (240X2) )
wich gives me 572mm - ( 72 + 480)
then 572mm - 552mm
wich equals 20mm
but then no 18' speaker has a depth of20mm
the 18g50 im going to use is 210mm
or are the dimensions in inches?
Thanks in advance...
eaw cabinet plans Socaflex Multi-Way 28 23rd January 2013 12:24 PM
Tempo cabinet plans rebojorge Multi-Way 10 28th June 2012 12:59 PM
AN-E cabinet plans... cypher Multi-Way 14 27th June 2007 08:06 PM
BLH Cabinet plans fin1bxn Full Range 3 27th June 2006 04:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
