Old 21st October 2007, 04:39 PM   #1
evad is offline evad  United States
Default Down facing drivers
This question has probably been asked and answered many times berfore, but the number and models of drivers change rapidly. "Are some drivers not meant for down facing? If so which, and what determines this"?
I'm interested in the PE 12" RSS315-4.
Old 21st October 2007, 04:50 PM   #2
myhrrhleine's Avatar
Floppyness of the cone.
Gravity pulls the cone down, out of alignment.
Thus it is no longer capable of equal +/- excursions and can distort.
VC misalignment with magnetic field also increases distortion.
Just because you can't hear it doesn't mean no one can.
Old 22nd October 2007, 04:13 AM   #3
This should answer all your questions about this.
Old 22nd October 2007, 04:20 AM   #4
ashok's Avatar
Check this free download
http://www.subwoofer-builder.com/sonosub.htm
AM
Old 22nd October 2007, 05:25 PM   #5
Thank you Gentlemen, I was sure you would know the answer to my dilemma. In the driver specs the Xmax of 14mm is not noted as peak to peak, so I am assuming it is one way, If so the sag is approx. 3.36% which is within tolerances. By the way BoomieMCT, talk about an out of the way link! Thanks for the resource page.
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
anybody facing stability problems with LM3886 BA100 with 8 ohm subwoofer? rhythmdiy Chip Amps 1 31st October 2007 06:04 PM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
XXLS low bass - Facing Front, Side, Down or Back DEQ+TheEnd Multi-Way 1 11th November 2006 11:26 AM
Rear facing ports MWP Multi-Way 2 4th December 2003 07:08 AM
Page generated in 0.08060 seconds (72.84% PHP - 27.16% MySQL) with 10 queries
