Hornresp - New Website Address - Page 3 - diyAudio
Old 3rd February 2008, 04:43 AM   #21
Originally posted by tb46
Thanks for your great program, I know it is repetitive, but I’d like to join the ranks of those who have expressed their thanks for a job very well done.
Thanks Oliver. Rest assured, receiving such positive feedback is never repetitive, as far as I am concerned :-).
I wonder how difficult it would be to add a series inductor (with inductive and resistive components) to the speaker parameter list (e.g.: in the background of the Le field)?
I will keep it in mind for possible future inclusion - the "to do" list just keeps getting bigger and bigger :-).
Kind regards,
David
Old 3rd February 2008, 12:20 PM   #22
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Default Re: Re: Question for David
Originally posted by David McBean
Hi ConExp,
The Combined Response tool was changed at Version 16.00. I found that techniques developed for the tapped horn model could also be applied to the combined response model. Predictions using Version 16.00 or later should be more accurate.
Kind regards,
David
Combined response calculation does not update phase plot. It would be great if it did.
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th February 2008, 03:32 AM   #23
Default Re: Re: Re: Question for David
Hi Eva,
I agree that it would be great if Hornresp could do all sorts of other things - unfortunately I have to draw the line somewhere, otherwise I would be working on the program 24/7 :-). I will nevertheless keep your suggestion in mind for the future - thanks.
Note that the current phase response chart only shows the phase shift through the driver itself, not down the horn as well.
Kind regards,
David
Old 4th February 2008, 12:22 PM   #24
Eva's Avatar
Would some donations change your mind?
Old 5th February 2008, 05:57 AM   #25
Hi Eva,
There is more to life than money :-).
To be perfectly honest, in the past I have really only added things to Hornresp that required me to learn something new - the tapped horn simulation model is a good recent example of that. The problem I now face is that a lot of the requests I receive are for enhancements that do not require me to gain new knowledge, so that the motivation to upgrade the program is not as strong.
Also, to do some of the new things properly would really require a total revision of the Hornresp platform and the (originally DOS-based) user interface. Unfortunately, I simply do not have the time or enthusiasm to undertake such a major re-build. It has taken me thousands of hours to get Hornresp to where it currently is - I have been working on the program in one form or another for over thirty years.
Perhaps I am just getting old and tired... :-).
Kind regards,
David
Old 5th February 2008, 07:20 AM   #26
Eva's Avatar
Horn phase response in the crossover region is a very interesting subject. Impedance peaks and the usually sharp LF roll-off result in gentle and wild phase shifts, sometimes over 180 degrees "p-p". I have done measurements but the software is weak (again!) when it comes to produce meaningful phase plots.
On the other hand, multi-way systems involving one or more horns without phase matching in the crossover region produce a typical horn-sound signature: Some frequencies are summing strong on-axis, others are summing only off-axis and others are just disappearing, and all this happens within only one octave or two. Optimum polarity or plain delay can produce some improvement but can't solve the problem.
Phase matching is much more important than an inherently flat SPL response, it is the key to get hi-fi sound from horns, and it is achieved by placing parametric EQs at the right frequencies with a DSP crossover. SPL response may be corrected later with a graphic EQ (which responds much better after matching).
The process of adjusting the parametric EQs by ear becomes quite easy if you have the tools to do some previous analysis and you know how many "positive" and "negative" bumps you have to flatten and their order. It becomes very hard if you don't have that data.
That's why I'm asking for meaningful phase plots.
If the the current plot is not including the horn, then, does it serve any purpose? I think it doesn't. Everybody using the program is expecting to get a phase plot modelled at the same place where SPL plot is. It's more like fixing a bug than like adding a feature.
Old 6th February 2008, 03:39 AM   #27
Hi Eva,
Have you tried using AkAbak?
Kind regards,
David
Old 6th February 2008, 09:48 AM   #28
Beware if he gives this advice ...
... once you get the hang of it, it's addictive!
-- If in doubt: overdesign!
Old 8th February 2008, 01:30 AM   #29
Eva's Avatar
Well, I suppose the battle is lost...
Old 8th February 2008, 05:28 AM   #30
Hi Eva,
Never give up - who knows what the future may hold for Hornresp :-).
The points made in your previous post are most valid, and have got me thinking…
Kind regards,
David
Hornresp David McBean Subwoofers 7531 Today 01:22 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Tapped and Hornresp help! DrWoofer.com Subwoofers 10 29th April 2008 03:02 AM
Copyright ©1999-2017 diyAudio
