A month plus ago, I had posted about wanting to get a sub to crossover with my BLH 12" Red Tannoys. The space for a sub was just too small and nothing would work well. I've done some reworking of the speaker/space so I have a little bit more room....not a lot...but wondered if it might be enough to reach the desired result.
The outside space is 8 3/4" tall, 18" wide and 19" deep. The height could probably creep up to 9" if necessary.
What I want is a sub to go up to 125HZ and down to about 40 HZ that is fast and good for 2 channel music. The sub would reside under each speaker.
I'm a good woodworker so a complex box isn't a problem. I know very little about speaker design. I'm not a moneybags but I like the mids/high smoothness of these speakers enough to spend fairly freely (if necessary) to get some decent bass and make them work for me.
do a search on this forum. Here is just one active thread right on the main page.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=108893
The back of the speaker will be angled to a wall so I was thinking that the drivers would need to be on the front or create a problem with the wall. Maybe I'm wrong? I understand that multiple drivers can help get better response with a small space so that's definitely a possibility.
I read the ripole info but I don't know how to model a speaker. I have a macintosh computer and can't run windows programs and most of the modeling software seems to be written for windows.
I saw a design from a couple of months ago that looked interesting. It had dual drivers and was like a transmission line/horn speaker and looked like it might almost work but it was about 2 foot deep and I've only got about 19". I don't know if the design would work with a shorter path.
- Subwoofers
- Small Narrow Subwoofer
