Old 18th October 2007, 02:37 PM   #1
Default New 12" subs for jukebox
Hey all great site. I'm a newbie to speaker building and came across this forum while looking for info on sub enclosure design.
I built a jukebox a while back but the PC speakers just didn't cut it for me. Here's a pic;
http://img513.imageshack.us/img513/9...kebox19wh2.jpg
I purchased 2 12" subs and a 350watt amp to power them. Below are links to the specs and some pics;
12" Sub specs - http://jaycar.com.au/productView.asp...ub&SPECIAL=&fo
Sub amp specs - http://jaycar.com.au/productView.asp...PECIAL=&form=C
12" sub - http://img141.imageshack.us/img141/2505/dscn0942yx1.jpg
12" sub - http://img84.imageshack.us/img84/1040/dscn0943zv8.jpg
12" sub - http://img84.imageshack.us/img84/1791/dscn0944vg3.jpg
12" sub - http://img99.imageshack.us/img99/6701/dscn0946mc4.jpg
Sub amp - http://img206.imageshack.us/img206/7128/dscn0948bd0.jpg
Sub amp - http://img206.imageshack.us/img206/19/dscn0949hh3.jpg
Sub amp accessories - http://img206.imageshack.us/img206/4489/dscn0950qn6.jpg
The 2 subs will mount just like in this similar cab... http://www.knievelkustoms.com/ms17.jpg
Would I be better off buying a premade enclosure and fixing it in place, or build my own? I have little knowledge of volumes/ports/vents etc. I asume though given the specs of the subs I need an enclosure volume of 158.908l?
I will also upgrade the mids/tweeters also but that's a nother matter I will deal with once I finish the subs.
I have no idea about wiring this system to give the best performance so any help there would be greatly appreciated also.
Will update with more pics as the process continues.
Cheers
Ben
Old 20th October 2007, 04:05 PM   #2
iUSERTLO72p's Avatar
Default Ben check this
http://www.linearteam.dk/default.aspx?download=winisd
Always better off building your own. Here at diyAudio.com, everyone is sure to help you. if you use winisd, others know the software, so will be able to help.
iUSERTLO72p
Old 21st October 2007, 09:21 AM   #3
I tried that program before posting here and found it too confusing lol.
What would be the ideal sub enclosure for these 2 12" drivers/amp for playing hard rock/heavy metal/top 40
Old 23rd October 2007, 01:47 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
...What would be the ideal sub enclosure for these 2 12" drivers/amp for playing hard rock/heavy metal/top 40...
Suggestions to chose from: 1(3), 2(3) and 3(3)
b
1(3)
Old 23rd October 2007, 01:49 PM   #5
2(3)
Old 23rd October 2007, 01:50 PM   #6
3(3)
Old 26th October 2007, 10:01 PM   #7
Hey thanks alot for those designs. I'll have a good look when I get a chance!
Old 29th October 2007, 08:54 AM   #8
I'm thinking of going with the first design...
http://www.diyaudio.com/forums/attac...amp=1193147259
Would this be a good choice?
Can I change the dimensions of the cab (but keep the same volume)?
Would 2 of these subs be a good match with a set of these?
http://www.theloudspeakerkit.com/sho...&ProcessType=1
Old 31st October 2007, 01:20 PM   #9
anyone?
Old 1st November 2007, 08:08 AM   #10
http://jaycar.com.au/productView.asp...=&SUBCATID=545
Would I just be better of getting one of these?
are bandpass subs passe compare to "horn-sub"? freddi Subwoofers 9 30th September 2007 07:54 PM
Dayton, SilverFlute, or Foster for my "subs" ? swak Subwoofers 4 22nd August 2007 06:44 PM
replacing 12" sub in box with back speaker mounted 6" subs aussiebuddha Car Audio 7 14th October 2006 08:26 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
Using "high-end" car subs for home? mazeroth Subwoofers 21 25th August 2004 01:39 PM
Page generated in 0.11633 seconds (77.94% PHP - 22.06% MySQL) with 11 queries
