home sub/ upgrade help
Old 19th October 2007, 05:03 PM   #21
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
I agree the 12dB/oct room gain is mostly a mythical beast, but there will be some gain.
Also as you say basing the need for 20Hz on the existing subs probably advertised similar figure is false. Done well a redesign of what he has will be quite an improvement I'd imagine even if it gets nowhere near 20Hz anechoic.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 19th October 2007, 05:15 PM   #22
GM is offline GM  United States
GM's Avatar
Originally posted by richie00boy
I was suggesting for the Monolith which he listed the specs for. A driver he is contemplating, i.e. does not own. He hasn't really given any real info on his current box, which is why I could not comment on it.
?? We've only been talking about the Monolith. Your unsubstantiated retort to me basically stated he can use it in a vented alignment driven with a 500 W RMS amp just fine without a PR, then turn around and say this isn't what you were recommending at all, but haven't offered any alternate that I can see, only strongly suggesting he shouldn't like/want what he does, a grossly presumptuous attitude IMO.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th October 2007, 05:47 PM   #23
Did it Himself
I think wires have been crossed somewhere. You said I was suggesting he builds a lower tuned version of what he already had. The seemed to conflict in my mind as I had not mentioned anything about what he already had.
Chill dude
Old 19th October 2007, 08:49 PM   #24
larksp is offline larksp  United Kingdom
right now i have a well rather than say ill give you a link to basicly what i have as it much easier and have a better idea to what it is
the subwoofer name /make
directed compx 5108 10inch subwoofer also a sub in its time would hit the $300 same price as the JL in its time
this should be near to dead on what i made
link
this was the first one i made... it does sound good to me not saying it cant be better and main thing i find wrong with some films it will vibrate alot and not quite right one some of the sounds e.g sea waves really deep i think chuffs a bit
Old 20th October 2007, 09:02 AM   #25
Did it Himself
That looks like a recipe for a lot of turbulence, a port with that many sharp bends. That alone could be improved by an L shape slot port.
Qts of the driver is quite high, more suited towards a sealed box really. However, I think a ported box could be done.
Old 20th October 2007, 11:25 AM   #26
that one does say ported when i enter details in
on there site it does say both sealed and ported but they tune it 2 35hz i think and small ish box
and then i have the JL why i was asking would the monolith make a big improvement for me.
on music the sub is good i did sand the edges down and most films it quite good
nice subwoofer it is deep
Old 20th October 2007, 11:36 AM   #27
Did it Himself
The way they tell you to tune it is a boom box for a car that will have unavoidable bad port chuffing as you can't fit a big enough port in the small box. Poor in a house IMO.
I've had a play and I can't really come up with a ported design I would be happy with. You could use it sealed with EQ but I think you might not want a project like that as it's harder to do and needs a bigger amp. I'll have a look at the JL if you put the parameters up. What is the price difference between the JL and the Monolith?
Where are you using this sub? I'm guessing you don't want a big box, bigger than 100 litres?
Old 20th October 2007, 11:43 AM   #28
yer i dont want bigger than that jl is 10inch sealed box where i like ported and
both car subs are 300rms
my amp 500rms at 4 ohms and is a plate bk amp
Old 20th October 2007, 12:10 PM   #29
R.I.P.
tell us the size of box you will accept.
regards Andrew T.
Old 20th October 2007, 12:26 PM   #30
well smaller is ok but i guess it depends on how much of an improvement it gives e.g
if i had a 40l box and then 80l would make it 10 times better then that would be ok
home sub/ upgrade helpHide this!Advertise here!
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
Stage one of upgrade to home system bludbunny Subwoofers 8 11th October 2006 09:46 AM
SF concerto home XO upgrade jomar Multi-Way 0 5th September 2005 07:34 PM
