Old 11th October 2007, 07:32 PM   #1
krokkie is offline krokkie  New Zealand
Default Flexible pipe subwoofer
Hi all
I remember seeing a design years ago consisting of a smallish speaker and a length of flexible ducting used as a sub.
I need more info on this type of design, or using pvc pipes. How do I calculate the length?
I want to build a sub for my Pajero, but do not want to take away too much space. I am thinking of installing it under the seats, or just behind it.
Any suggestions?
Old 12th October 2007, 03:52 AM   #2
JinMTVT is offline JinMTVT  Canada
that brings me to think of something ..
what happens to the rear wave ( or any wave )
that would travel through some enclosure
that it would inflate with the pressure or move?
would the wave dissipate using its power ??
sorry for highjackin ur thread
Old 15th October 2007, 12:04 AM   #3
Is there a way I can maybe use a PVC pipe mounted behind the seat?
How do I workout the length of the pipe?
Old 16th October 2007, 06:27 AM   #4
djk is offline djk
djk's Avatar
The large diameter sub was mounted to a board in the trunk (boot), and the flexible tube went up to the narrow rear deck (package shelf).
Candidates for the Darwin Award should not read this author.
Old 16th October 2007, 11:14 AM   #5
OzMikeH is offline OzMikeH  Australia
You might be thinking of a transmission line sub. It'll never fit in a Pajero. (apologies to Spanish speakers out there, no profanity intended - they really did name a car that!)
They need to be a quarter wavelength long, HUGE. they are usually close to the diameter of the driver, not sure what will happen with a thinner pipe.
Suggest 8 or 10 inch very high excursion drivers with the highest efficiency you can find in a correctly designed sealed or bass reflex box. Make the footprint the same as an Engel (I think they're called an Ingl over there ) so you can pop it in and out if your get a car fridge and secure both of them safely with one of those slider thingies. If you put a fridge in for a trip you;ll need to remove the sub for the space, two birds and all that...
Old 18th October 2007, 06:35 PM   #6
Thanks Mike
It helps a lot, I think I might just spend more time setting up the 6x9's in the back, they should provide ample bass.
I don't really want to take away any space, especially in the rear, as the Pajero is used over weekends for fishing, etc, and it's a hassle to take out a sub all the time.
Cheers
Jacques
Flexible Cable Kral57 Everything Else 0 10th September 2008 06:21 PM
Voigt tapered pipe as subwoofer hahfran Multi-Way 5 13th February 2008 08:43 PM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 09:00 AM
flexible wire johngalt47 Parts 5 10th January 2005 12:35 AM
Flexible plywood.... jonz Multi-Way 4 5th June 2004 10:11 PM
Page generated in 0.07528 seconds (78.47% PHP - 21.53% MySQL) with 10 queries
