Hi All,
I've been enjoying the forums for quite some time now and had the idea to build a subwoofer. So what I did was go out and test some that I would like to build, the three it came down to was: B&W ASW855 $6k Velodyne DD15 $5.7k Velodyne DD18 $6.7k I was thinking I could build one, but would it sound as good? Would it turn out to be utter cr@p! What to do? |
#2 |
diyAudio Moderator Emeritus
Definately build one yourself!!! There are a lot of great subwoofer builds out there. Getting it to look good is usually the challenge. Getting it to sound as good or better is the easier bit. There are classD subwoofer amplifier units that you can buy. (Probably the same as B&W are using)
At those big brand names you are paying for the name/marketing etc. |
#3 |
Now it all sounds fine but; can it have a medical application......or possibly be used in national defence? Just see if Mr. Howard can give you a bribe SORRY, SORRY, wrong word.....a grant, that's it, a grant..... This is definitely the month to seek a favourable response for Federal Gov't assistance.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#4 |
If you really think a subwoofer is what you want, there are a lot of options out there as far as those go..
DON'T BUY ONE, BUILD YOUR OWN! Tons of possibilities with different types of sealed, vented, transmission lines, horns, infinite baffle, open baffle (u frame, h frame, etc).. 12"-18" subwoofer drivers for around $150-$400 USD each, depending on what you want to do. A VERY good professional rackmount amplifier, taking just about any reasonable load thrown at it and powering just about anything you could possibly need to use it for, can be purchased for roughly around the same price. ..$6k AUD?? I don't think so!! I hate it when people do this. |
#5 |
RYTHMIK servosub kits are said to be the closest you will ever get to Velodyne ... at 1/10 of the cost ... so how many do you want
But I suppose you will need a 6-band bassEQ like the one from ESP or maybe something digital Maybe this digital xo with EQ will be good fore a sub http://www.groundsound.com/dcn23.html |
#6 |
Just give me the 6k. At least one of us will be happy then.
Build it yourself. If you have a loft then an Infinite Baffle will destroy anything you can buy commercially from one of the audiophile jewellers. http://ibsubwoofers.proboards51.com/ http://home.comcast.net/~infinitelybaffled/ |
#7 |
I'm a HUGE supporter of using EQ to reduce the effect of room modes in a subwoofer. There is no need to run out and get a $400 Velodyne SMS or similar unit. The Behringer Feedback Destroyer (BFD) in relatively inexpensive and has been used by many to tame LF room modes. See this link for much more info (and lots of free downloads):
http://www.hometheatershack.com/forums/bfdguide/ As far as building your own - you can do as good as most production subs for much much less DIY. |
#8 | |
Manually edited by mod. |
#9 | |
i agree i am very happy with my tapped horns, which i build around two old 10 inch woofers which were unused for some years. definitely better than every sub i heard until now - which were all commercial ones at friends houses. try to build your own, its fun and should have a nice "wow" effect. |
#10 |
I'm building my own sub using a TCSOUNDS driver but since they've ceased selling to the public I thought I'd recommend one of their commerical products. Have a look at this sub . This and a Buttkicker amp and you'd be off to a good start for around $1200.
Regards, Dan |
| I've lost my mind | bjackson | Multi-Way | 3 | 30th October 2005 05:58 AM |
| Help with spending my money | michael | Multi-Way | 10 | 22nd January 2004 12:02 AM |
| Spending my Hard Earned Cash | griff | Everything Else | 1 | 18th February 2002 10:35 PM |
| Ok ok, so i changed my mind.... | Lisandro_P | Solid State | 7 | 24th July 2001 02:10 AM |
| Page generated in 0.10927 seconds (80.42% PHP - 19.58% MySQL) with 11 queries |
