Hello everybody,
I read in brochure of M3DS from MEYER sound this subwoofer have a directivity, but they dont tell the exact way. Has any one try to made or experiment to made a DIY directional subwoofer ? dont mind to share the recipe ? |
#2 |
Is the M3DS an array? Meyer is known for their phased arrays, which are steerable, but it seems to me that steering sound at very low frequencies would be problematic.
Nihilism is best done by professionals. |
#3 |
It's cardioid sub, I guess it is obtained by using front/rear woofers and properly delaying the rear woofer such that to obtain a cardioid pattern.
It can also be done DIY. An example is NaO which uses a U-Frame: http://www.musicanddesign.com/NaO-II-U-frame.html There was also a 2-woofer version somewhere, but I couldn't find it anymoore. |
#4 |
Maybe it was at Meyer sound, but I read someplace that you can get similar directionality to microphone patterns like cardioid or figure-8. It requires multiple subs, spaced apart and with time delays so that there's gain in one direction and cancellation in the other. It might be practical for a large suburban property where money isn't an obstacle, or outdoor concerts.
#5 | |
Arranged like that they will add together on the line where the difference in distance equals a half wavelength and cancel eachother on the sides where there arent any delay between them. The meyers work in a similar way as that. They have 18incers on the front and 15inchers on the back that are out of phase with eachother in a way that makes them add constructively infront of the box and destructively behind the box, Thereby making the bass directional. http://www.meyersound.com/products/mseries/m3d-sub/ "A pair of 18-inch drivers is mounted at the front of the cabinet, and works in conjunction with a pair of 15-inch drivers facing the rear and is driven by a sophisticated phase manipulation circuit." |
#6 |
perhaps one could put a closed box sub and a dipole sub, both using the same driver, equalised to the same response, on top of each other (perhaps with the monopole firing to the rear and having reversed polarity). the back wave of the dipole is out of phase with the monopole, so they should cancel, which would leave only the front lobe of the dipole figure of eight.
is that possible? |
#7 | |
www.dipolplus.de |
#8 |
Thanx for made it better to understand. I will try it soon |
#9 | |
Thanks for the information. Very interesting! |
| Uni directional mic - help needed | Wavebourn | Instruments and Amps | 0 | 6th January 2007 12:49 AM |
| Directional Baffle questions | mashaffer | Multi-Way | 1 | 3rd June 2005 07:50 PM |
| Directional speaker placement | jered22 | Multi-Way | 4 | 10th January 2005 04:11 PM |
| directional speakers? | morsey | Multi-Way | 1 | 11th May 2004 04:17 PM |
| Page generated in 0.09577 seconds (80.33% PHP - 19.67% MySQL) with 10 queries |
