HI
i AM ANXIOUS TO BUILD A SEALED (FOR SIMPLICITY) SUB IN ABOUT A 3 CU FOOT BOX. i HAVE ORDERED A BASH 500 PLATE AMP AND THE 3/4 MDF. HOWEVER PICKING A 12 " DRIVER IS REALLY OVER MY HEAD. i WAS THINKING OF GETTING THE XJ-12 FROM DIYCABLE.COM FOR $175 SHIPPED. THIS IS A NEW DRIVER, AND I DON'T AM HAVING SECOND THOUGHTS. aNY SUGGESTIONS ON ALTERNATIVE DRIVERS? THANKS SCOTT XJ-12 DRIVER xmax: 27mm Re: 3.95 Ohms Qts: 0.58 Qes: 0.67 Qms: 4.35 Fs: 31.5Hz mms: 114g cms: .225 mm/N BL: 11.43 Vas: 83L SPL: 87.7 Sd: 506.7 cm^2 |
#2 |
Good morning Scott. Firstly a quick word about your post - using all capitals is regarded online as shouting, and is very impolite.
As regards your prospective driver, I don't have time to model it for you, but it looks OK at a quick glance, though the Fs is a little high for a true sub. What I would suggest is a little research. The plate amp you have ordered looks fine to start, but regarding the driver, have a look around here and the web for completed projects, and for a first attempt, copy one of those. This is not to say that designing a sub is complicated, it isn't, but you need to have a basic understanding of what the component parameters mean, and how to use modelling software to get the response you require. Are you up for a little reading, or do you just want to chop wood?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| First project for novice | dannycelluk | Introductions | 4 | 31st March 2009 08:36 PM |
| A few questions from a total novice. | bonescan | Tubes / Valves | 13 | 24th March 2009 08:14 PM |
| Could anyone help a novice? | sunnycue | Full Range | 8 | 4th August 2006 05:45 AM |
| Novice in need of help | skiermurph | Solid State | 2 | 22nd December 2004 01:52 AM |
| Page generated in 0.07884 seconds (74.07% PHP - 25.93% MySQL) with 10 queries |
