I would like an advice on the best sub that could be built out of a pair of drivers with the following specs
Fs:38Hz Vas:50 L QTS:0.8 Max Power:150W Currently thinking of a sealed sub using a linkwitz transform aiming for an equalized Q of 0.8 and FS of around 30 t0 25Hz using a 40Litre box Is there a possibility to use both woofers in a sealed push pull arrangement in combination with a linkwitz transform? Would it also be possible to have both woofers in an isobaric config still using a sealed box? Thanks |
#2 | |
A push-push sealed box can use an LT. Most isobarics are built with the rear driver in a sealed cab. |
#3 |
I would (and did) go push-pull. You'll need twice the airspace naturally, but you'll also get twice the output and twice the power handling.
With isobaric, you can use both drivers in the same airspace as a single driver, you get the same output as a single driver, but still gain twice the power handling.
Charles |
#4 | |
With push-push, you'll also get lots less cabinet vibration. |
#5 | |
Yes, you're correct Brett. Thanks for pointing that out. Sorry, it's late and I'm extremely tired and should be in bed... Which is exactly where I'm headed off to right now.
Charles |
#6 |
So a push-push config would mean having two drivers in one box with both cone pointing outwards?
Is there any advantage that the push-push might have over the push-pull or vice-versa? Thanks |
#7 | |
b 1(1) |
#8 | |
Regards Charles |
#9 |
Thanks for the posts greatly appreciated. I do not have any info about the Xmax but the target SPL should be around 95dB. Will a bridge 120W per woofer be sufficient ?
#10 | |
| 70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. | facundonu | Multi-Way | 34 | 9th March 2009 04:59 AM |
| FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers | omarmipi | Swap Meet | 0 | 19th November 2007 04:21 AM |
| Two drivers one selaed box | zeus_threat | Multi-Way | 9 | 6th September 2007 06:15 PM |
| WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. | Spasticteapot | Swap Meet | 1 | 5th November 2006 03:31 PM |
| Page generated in 0.11651 seconds (81.54% PHP - 18.46% MySQL) with 11 queries |
