Two 10" drivers selaed sub
Old 24th September 2007, 07:20 PM   #1
zeus_threat is offline zeus_threat  Mauritius
Default Two 10" drivers selaed sub
I would like an advice on the best sub that could be built out of a pair of drivers with the following specs
Fs:38Hz
Vas:50 L
QTS:0.8
Max Power:150W
Currently thinking of a sealed sub using a linkwitz transform aiming for an equalized Q of 0.8 and FS of around 30 t0 25Hz using a 40Litre box
Is there a possibility to use both woofers in a sealed push pull arrangement in combination with a linkwitz transform?
Would it also be possible to have both woofers in an isobaric config still using a sealed box?
Old 25th September 2007, 12:18 AM   #2
Brett is offline Brett
Brett's Avatar
Default Re: Two 10" drivers selaed sub
Fs:38Hz
Vas:50 L
QTS:0.8
Max Power:150W
Q is a bit high for my tastes.
A push-push sealed box can use an LT.
Most isobarics are built with the rear driver in a sealed cab.
Old 25th September 2007, 02:48 AM   #3
chops is offline chops  United States
chops's Avatar
I would (and did) go push-pull. You'll need twice the airspace naturally, but you'll also get twice the output and twice the power handling.
With isobaric, you can use both drivers in the same airspace as a single driver, you get the same output as a single driver, but still gain twice the power handling.
Charles
Old 25th September 2007, 02:58 AM   #4
Brett's Avatar
Isn't isobarik 1/2 the cab size generally?
With push-push, you'll also get lots less cabinet vibration.
Old 25th September 2007, 03:05 AM   #5
chops's Avatar
Yes, you're correct Brett. Thanks for pointing that out.
Sorry, it's late and I'm extremely tired and should be in bed... Which is exactly where I'm headed off to right now.
Charles
Old 25th September 2007, 10:14 AM   #6
Default Push-Push layout
So a push-push config would mean having two drivers in one box with both cone pointing outwards?
Is there any advantage that the push-push might have over the push-pull or vice-versa?
Old 25th September 2007, 11:25 AM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
I would like an advice on the best sub that could be built out of a pair of drivers with the following specs...
Difficult to answer when not knowing the driver brand name, x-max and the SPL requirement?
b
1(1)
Old 25th September 2007, 12:29 PM   #8
phase_accurate is offline phase_accurate
The advantage is called "pulse compensation" - meaning less vibration of the box - which you would only achieve with a lot of weight otherwise.
Charles
Old 27th September 2007, 07:29 AM   #9
Default Thanks
Thanks for the posts greatly appreciated. I do not have any info about the Xmax but the target SPL should be around 95dB. Will a bridge 120W per woofer be sufficient ?
Old 27th September 2007, 07:32 AM   #10
Brett's Avatar
Default Re: Thanks
How can we possibly answer that without more driver specs. It'd just be a wild guess otherwise.
Two 10" drivers selaed subHide this!Advertise here!
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
Two drivers one selaed box zeus_threat Multi-Way 9 6th September 2007 06:15 PM
WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. Spasticteapot Swap Meet 1 5th November 2006 03:31 PM
