i have a bazooka 8in powered sub. anybody ever convert one of these to use in a surround application. don't really want to sell it, but i do want to use it. i was thinking of either using an ac converter or changing the power supply. so is it a go or no go. shoot ideas at me. thanks!
#2 |
Throw it in the garbage where it belongs.
#3 |
Sell it on Eb@y, make it someone elses problem. Then use the money to purchase something better, try a raw driver from PE
I'm actually running a sub driver that was originally designed for car audio/PA, but it's an 18" Cerwin Vega in a 7cu ft box, and it works pretty well once you tune out the 60-80Hz bump. That little 8" tube won't do anything but make a faint noise. The volume of the room is way too large. If you're absolutely set on using it, yank the battery out of your car and hook it up in the livingroom to test it out. Though you don't want to run this long-term as the gasses given off by a lead acid battery in addidion to the risk of acid leaks can be deadly. Don't use a battery charger, as it will create noise and distortion in the signal. A true 40+A 12V power supply will run you over $300.00 |
#4 |
yea rite 8inch is nothing for a room, sell it off
plus its the same old problem car and Home audio dont ever mix |
#5 |
yeah. it was just a thought. just upgraded the car system so its just laying around.
| Converting SS eq. to Tube | mashaffer | Tubes / Valves | 12 | 17th January 2009 05:38 PM |
| Converting tube guitar amp to Hi-Fi amp | roots | Tubes / Valves | 10 | 3rd April 2008 02:00 AM |
| Converting a car amp to home amp | zx3chris | Car Audio | 2 | 29th January 2004 02:36 PM |
| Page generated in 0.06607 seconds (73.31% PHP - 26.69% MySQL) with 10 queries |
