embarrassed to ask...
Old 16th September 2007, 04:23 PM   #1
Shpoop is offline Shpoop  United States
Default embarrassed to ask...
Well, all my college friends and roommates know I like DIY speaker building and all, so they often come to me for advice. I am quite embarrassed to say that I had no answer for a recent, easy question.
Someone approached me saying that their logitech sub (one of those pretty nice sized ones) says to not place it near electronics. He asked me two questions.
1) Can he place it right next to a refrigerator without any concerns? I can't image there would be any problems...
2) How close clan he place it to a big, 35'' sony trinitron TV (a tube TV) without any screen interference or damage to the tv? For this I guess it's more of a guess-and-check solution, but can you guys give me a ballpark estimate? Let me know if you guys want the exact model number, but I assume all of the "big logitech subs" are pretty much identical.
Thanks a million!
Matt
Old 16th September 2007, 04:54 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
1) I wouldn't place it right next to the fridge, the vibrations might rattle the beer and cause excess foamage.
2) "guess-and-check" is about right. Turn the TV on and start moving the sub toward where he wants to put it. If at anytime while it's being moved closer the screen color starts to distort, then it's too close. I would guess you can get within 2-3 feet with no problems.
Old 16th September 2007, 07:22 PM   #3
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Near a TV won't break the TV.
It can mess up the colour, but it isn't broken.
Most TVs automatically fix themselve.
The Bzzzz heard at turn on is the demagnitizing process.
If it's too close, the colours get wrong.
Just move it farther away until the problem goes away.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 16th September 2007, 08:02 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Re the fridge, you'd be more worried about noise from the fridge getting into the Logitech via the power connection.
With the TV, just move the sub towards the TV until it starts to rainbow. Then back it off quickly. If you set the woofer near to that close, keep an eye on the corner of the TV near the woofer -- if it starts getting "colourful" move the woofer a bit further away.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th September 2007, 08:19 PM   #5
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Since TVís usually donít come with an auto-demagnetizing function, he will need to turn it off (mains switch) for 15 minutes if his colors accidentally get mixed up.
/Hugo
Old 16th September 2007, 09:51 PM   #6
/Hugo
Is my age showing?
have they discontinued degaussing coils around the tube?
Old 16th September 2007, 10:15 PM   #7
Netlist's Avatar
There is degaussing and auto-degaussing.
TV's need to be switched off for the degaussing circuit to work. (PTC)
An example of auto-degaussing is the Philips Brilliance 201CS monitor. A clever circuit detects changes in close proximity magnetic fields.
When I rotate the mid and tweeter part of my speakers, the effect on the colors is immediately corrected by the auto degauss system.
/Hugo
Old 16th September 2007, 10:27 PM   #8
AKN is online now AKN  Sweden
No snake oil
AKN's Avatar
embarrassed to ask... Send a message via MSN to AKN
Originally posted by myhrrhleine
Is my age showing?
No and no
CRT TV's usually have demagnetising coils in series with a PTC resistor connected to mains switch. This means that every time the TV is turned on with the mains switch, CRT gets demagnetized for a moment with mains frequency magnetic field.
If however CRT gets severely magnetised the built in coil may not be effective enough. Using a large external demagnetising coil can help in such cases.
Edit: I was away for a moment, did not see your post Hugo.
/ Anders
Old 17th September 2007, 01:59 AM   #9
Hey guys. Thanks for the plethora of valuable information. This place never disappoints.
Matt
Old 17th September 2007, 03:18 AM   #10
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
my panasonic has a "geomagnetic correction" feature to fine tune the TV for large magnetic fields. I guess geologically large.
embarrassed to ask...Hide this!Advertise here!
embarrassed to ask but Pbassred Solid State 8 8th February 2006 11:08 AM
