Old 1st September 2007, 06:02 PM   #1
Default Clipping - power supply?
I have an AR S500 subwoofer that is clipping badly at moderate to high levels, I have replaced the driver, and found a good working amp out of a 220 V unit and replaced all the boards except the power supply (of course) with no change, so my problem seems to be centered around the power supply.
This is a Sunfire 500W RMS plate amp with a large toroidal power supply transformer. Should I replace this or the two large capacitors that make up this power supply? I'm no technician.
Thank you!
Old 1st September 2007, 10:10 PM   #2
Never mind, I found the problem - one of the caps was bad.
Pre-clipping as a method of power regulation bkoopman Class D 0 1st May 2008 06:18 AM
Clipping and amp power supply digitaldisaster Chip Amps 3 3rd September 2007 03:53 AM
Power Amplifier Clipping Indicator widi Solid State 2 1st March 2007 02:50 AM
Clipping vs Screwing Down Power Chips CarlosT Chip Amps 34 18th December 2006 09:15 PM
Sansui BA3000 clipping before peak power. Netlist Solid State 2 28th July 2006 07:41 PM
Page generated in 0.06486 seconds (67.60% PHP - 32.40% MySQL) with 10 queries
