Ultra sound transducer for servo feedback subwoofer?
Old 12th February 2003, 10:32 PM   #21
e96mlo is offline e96mlo  Sweden
So you still have to integrate. But then you will filter out the wanted error signal. How do you get around that?
/Marcus
Old 12th February 2003, 10:45 PM   #22
On Hiatus
SY's Avatar
If you want to make an error correction signal proportional to displacement, yes, you have to double integrate. That doesn't get rid of the signal, it just gives it a second order slope in the frequency domain. Effectively, it limits the usefulness of accelerometer servoing to low frequencies.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th February 2003, 09:01 AM   #23
But can you set the integrator poles high enough to not filter the feedback signal too much while still having the f^2 correction?
Also, doesn't the integrator have to be compensated for, or the system will be unstable?
I just recived my accelerometers from AD!
That reminds me; the guys at AD didn't compensate for the f^2 factor. Is that the reason for their mediocre results?
/Marcus
Old 13th February 2003, 01:23 PM   #24
On Hiatus
SY's Avatar
No, you want to set the integrator poles pretty low, lower than your desired cutoff. It reduces the feedback at higher frequencies, but that's where you have lower displacement (lower distortion) anyway. I think a lot of this is discussed in the Velodyne patents- you might spend a few minutes at the uspto site and download/read them.
The AD guys (it was actually a college project, not something done by AD staff) did not use a double integrator. Nor proper phase adjustments. It looked like it was a hurry-up job for a summer semester credit. We hobbyists can be a bit more patient and thorough.
How much do those AD accelerometers cost? I lucked out, have a drinking buddy who's a big shot analog guru there.
Old 13th February 2003, 01:34 PM   #25
I don't know how much they cost. I got them for free through their samples program as I have a small company. I've heard others complain on the high price, though.
Didn't know about the Velodyne patents. Thanks for the tip!
/Marcus
Old 13th February 2003, 01:47 PM   #26
On Hiatus
SY's Avatar
IIRC, the listed inventor was David Hall, if that helps your search.
The uspto is a treasure trove of useful info.
Old 14th February 2003, 07:15 AM   #27
I've read some in the Velodyne patents now but I couldn't find much info about poles and phase compensation and such.
Perhaps it wasn't needed for getting the patent.
/Marcus
Old 14th February 2006, 12:21 PM   #28
hilbren is offline hilbren  Netherlands
I know this is an old topic, but is a constantly repeatable topic so... kick!
A few replies back there was a theory why a capacitor mic could not be used.
But my theory is that most recording are done with capacitor like microphones. and we audiofreaks want to reproduce this!
The ideal situation is as following:
There is a sound named "A" if we record the sound with a cap mic (most cases) we get the speed of the air! *1
The recording we now have is signal "B" (differentiated signal of "A")
So we buy the recording in the store (cd or some thing like it) and it contains a differentiated recording!
So we want to reproduce the signal "A" and not signal "B"
And most speakers do that because the acceleration is at highest when the voltage is at peak. But as the frequency gets lower the speaker will sooner get to the ideal point when the resistance of the speaker hanging is equal to the voltage that is offered. So the integrating stops at that point!
This is the same reason why you need a very high Xmax for a Servo Subwoofer! Because the feedbackcircuit won't accept the speaker from stopping when there's still air to be moved!
(Example) so now the mic comes in when the sound "A" was recorded at some point the speed of the air was very high. To reproduce the same sound the speed of sound must be at the same level. So we place a capmic in the speaker and we want the speed of the air exactly the same as it was during the recording!
This way you should reproduce exactly the same sound!
In short:
1 Sound music
2 recorded Sound (differentiated by the mic)
3 sound out of the speaker (integrated by the speaker/feetbackmic)
4 real music!
*1 i tested the with a mic, a constant airspeed gives a dc offset
Old 11th July 2013, 04:59 PM   #29
esl 63 is offline esl 63
If you integrate a sine function two times you get a... sine function with reversed polarity.
So you take a piezo tweeter, an impedance buffer amp (OP) close to it. Mount the tweeter to the element, near the voice coil, and as stiff connection as possible.
The signal is filtered, feedback adjusted. And thats it!
I will put up some schematics one day...
Ultra sound transducer for servo feedback subwoofer?Hide this!Advertise here!
Help with DC Servo for Current Feedback Opamp klewis Chip Amps 31 4th June 2010 05:18 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
Where to put DC feedback for a servo integrator rtarbell Solid State 2 26th August 2006 03:00 AM
Servo-feedback Subwoofer dswiston Digital Source 25 26th October 2005 05:07 AM
Bandpass box with servo feedback??? Circlomanen Subwoofers 0 16th August 2005 04:30 PM
