Enclosures made of CARBON FIBER laminates ???
Old 21st August 2007, 04:42 AM   #1
JinMTVT is offline JinMTVT  Canada
Default Enclosures made of CARBON FIBER laminates ???
as i am working with carbon fiber right now for R&D purposes ( structural unidirectional prepeg stuff ..
not fenders and decorative products )
i thought about using some CF prepeg + core sandwiches for enclosure ...
i am pretty sure that i can make an enclosure of regular subwoofer size that will take as much power to flex as a few inches think concrete box would ...
all this for probably 1/10th the weight of the wood box
anyone ever used such material ?
the only drawback i'd see, would be the movement of the box on floor when energized because of it's low weight ???? ( could be overcome by fastening it nah? )
just a quikc thought ...
CF used to be really expensive ... now already make alum or balsa core sandwichs with woven prepeg can be purchased quite cheaply ...
Old 21st August 2007, 04:54 AM   #2
454Casull is offline 454Casull  Canada
You can overcome the low mass of such an enclosure by using two drivers in push-pull operation.
Old 21st August 2007, 05:43 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
They would have to be arranged push-push... (whether the drivers are arranged to do push-pull or not doesn't matter)
Wilson-Benesch have a CF woofer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st August 2007, 03:15 PM   #4
clever
Old 21st August 2007, 03:20 PM   #5
my Mirage BPS sub is of push-push arrangement ..
i believe that this is a very good design for control ..
but does it work only good at a certain freq depending on the distance from the 2 drivers??or it works at all freq ? is there any disadvantage to push-push ?
Old 21st August 2007, 06:11 PM   #6
frugal-phile(tm)
planet10's Avatar
Works at all frequencies. Only disadvanatge is you need 2 woofers and have to take a bit more care in the build to maximize the benefit.
dave
Old 21st August 2007, 06:14 PM   #7
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
CF could probably also work well as a case for a preamp, etc. as it would conduct electricity. So if you grounded it, would be a Faraday cage.. With Neodymium drivers, what a great portable PA it would be!!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 21st August 2007, 06:29 PM   #8
nice
yes of course, carbon wire is very conductive
what is the radiation pattenr of push-push drivers?
i am pretty sure i've seen a few graphs around here,
but i can't remember in wich thread ...
is the radiation affected by the distance between the 2 drivers ??
is guess there is not limit to how many pairs could be used side to side on an enclosure
Old 21st August 2007, 06:58 PM   #9
frugal-phile(tm)
planet10's Avatar
It is a subwoofer. All subs have an omnidirectional radiation pattern* whether they have 1, 2, or 10 drivers. Doesn't matter what side of the box you put them on either as far as that goes. Within the confines of a house you would be hard pressed to build any practical sub that had the drivers too far apart.
In a push-push sub, maximum benefit is had when the woofers are close coupled, and this is easiest to do if they are in close proximity to each other.
*(not strictly true if one considers dipoles and some of the cardioid pro-subs)
dave
Old 21st August 2007, 07:27 PM   #10
diyAudio Editor
Variac's Avatar
Do you know a source for this stuff?
Enclosures made of CARBON FIBER laminates ???Hide this!Advertise here!
A Carbon Fiber store!! DaveThreshold Analogue Source 9 11th May 2009 05:52 AM
carbon fiber earing Instruments and Amps 8 13th March 2007 06:04 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 04:57 PM
Cutting Carbon Fiber user510 Analogue Source 6 25th December 2003 05:40 AM
CArbon fiber enclosure jouch Multi-Way 1 14th March 2002 11:49 AM
Copyright ©1999-2017 diyAudio
