Enclosures made of CARBON FIBER laminates ???
Old 22nd August 2007, 10:41 AM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Dave, you are right ... if there is the least small drag between the two drivers there is a big risk of ripping the magnets and poleplares apart
Old 25th August 2007, 01:27 AM   #22
buggsson is offline buggsson  Sweden
Taking it a step further would use ready rod as common bolts for the drivers
That is actually what is in my (current) plan, in a slightly different application, for whenever I actually comes around to start building the thing. Hopefully later this fall.......
Old 25th August 2007, 01:53 AM   #23
On Hiatus
SY's Avatar
Epoxy-carbon composites typically have densities similar to dense hardwoods or even higher. There are some specialty low-mass composites, but those are pretty exotic- usually, wood is lighter for a given part size. Not as strong, though, which is why CF composites are useful in bikes and airplanes.
CF composites also tend to be more "ringy" than wood. Something worth exploring is loading the resin with hollow microspheres, which can help damp things and drop the density significantly. If you can run the process reasonably hot, something like a 3-4% addition of Expancel into the resin during impregnation could prove useful. Then during layup and cure, raise the heat to the expansion temp of the spheres and the composite will puff up like Jiffy Pop. Well, maybe not that much, but you can easily get a 40-50% expansion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th August 2007, 02:16 AM   #24
Brett is offline Brett
Brett's Avatar
Originally posted by OzMikeH
the large chunk of aluminium would cost as much as the drivers!
Can't see why a length of sonotube wouldn't work. Stiff and well damped.
I plan to build my 2 x 18" lower bass enclosures this way and otherwise similar to the drawing above with the threaded rods.
Old 26th August 2007, 01:23 AM   #25
Daveis is offline Daveis  United States
How thick/many layers would you need to get the same strength and deadness as 3/4" MDF ?
Are the chemicals you work with safe enough to not need a respirator?
(Seem to remember plastics solvents are bad to breathe)
Old 26th August 2007, 03:11 AM   #26
JinMTVT is offline JinMTVT  Canada
the prepeg i use has already been half cured..
so no it is not 100% safe, but i only use a small vent by convection on my oven and it is more than sufficient..
but for using prepegs for boxes, one would require a pretty big oven that could be controlled pretty accuratly
( our cure cycle as some ramps and is 130C for 1.5hour...
the epoxy goes back to semi-liquid and then starts curing when it hits 120c+ , then you need some time to let it solidify when bringing the temp down )
MDF is what, 3-4KPSI ? CF is roughly 300KPSI in TS
and half that in Comp S
so not much is required if you use some aluminum or balsa core to get a few times more stiff than 3/4 MDF
thing is that, because it will be seriously lightweight
you want to consider using something like 1"thick core,
as the weight incresase will be marginal, but stiffness will be multiplied VS .5 or .75" thick ..
probably 1-2 layers of CF inside and out would be more than sufficient ..
corners will need more attention and different use of CF
also the contour of the driver's hole would require attention to detail, as CF composites surface is very fragile because it is only the resin that is holding up,
so it is not very hard ( 6-8K PSI for the epoxy i believe)
Enclosures made of CARBON FIBER laminates ???Hide this!Advertise here!
A Carbon Fiber store!! DaveThreshold Analogue Source 9 11th May 2009 04:52 AM
carbon fiber earing Instruments and Amps 8 13th March 2007 05:04 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 03:57 PM
Cutting Carbon Fiber user510 Analogue Source 6 25th December 2003 04:40 AM
CArbon fiber enclosure jouch Multi-Way 1 14th March 2002 10:49 AM
Copyright ©1999-2017 diyAudio
