on payday this month i will be buying a subwoofer for my bedroom audio, the problem is the small speakers that i use are in full range at the moment and when i put the subwoofer in would like to have a bass pass filter on them at about 50hz where they start to drop off naturally so that when pushed to high SPL's i dont get the port chuffing noises, i could always bung the bassport on the back but not sure weather the response curve would be as good as it is with.
so what im basically asking is are there any good designs out there for a passive 50hz bass filter? |
#2 |
Speakerholic
A 50 Hz passive XO will be very expensive. Consider using an active filter. In fact, you can often buy a plate amp with a built in XO for little more than the components needed for a passive 50 Hz.
#3 |
Banned
I would just place a capacitor at the input of the poweramp |
#4 | |
frugal-phile(tm)
http://t-linespeakers.org/tech/filters/passiveHLxo.html dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
I use a 150microF electrolytic in series with the woofer input on the speaker. If your speaker only has 2 posts, you can add a 10microF polypropylene cap in parallel. My 2 way bookself has a 5.25" mid-woofer.
#6 | |
frugal-phile(tm)
dave
#7 |
sorry, i should have posted some more info.
the sound is going to be sent to my amp which has a dedicated line out for subwoofer which i am planning on using thats all fine however i would like to filter the the speakers on from the standard binding posts and was wandering about decent crossovers? i can spend about £200 for the pair? any ideas? |
#8 | |
frugal-phile(tm)
A passive XO on any speaker this low and this close to its cutoff is a nightmare and will likely be a waste of effort. You can't get at the power amp separately? dave
#9 |
sorry to take the poster over put i cant post in the main room
#10 |
So you just wanna high-pass the satellites using a passive x-over? Wouldn't the amp/system be doing this for you actively? If not (odd), you could just try a cap in series with the satellites but it may not be steep enough depending on the x-over freq.
As stated, a passive x-over at such a low freq is a pain in the a*se (but at least its a high-pass and not a low-pass!!!). |
| PE Dayton passive crossovers | madpoet | Multi-Way | 1 | 3rd June 2005 03:02 PM |
| why do we bother with passive crossovers? | paulspencer | Multi-Way | 70 | 13th September 2004 07:06 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Some basics abt passive crossovers. | rakeshln | Multi-Way | 6 | 31st May 2004 11:55 AM |
| Solder for passive crossovers. | JoeBob | Multi-Way | 8 | 31st December 2001 04:28 PM |
| Page generated in 0.09837 seconds (80.46% PHP - 19.54% MySQL) with 10 queries |
