Hi Guys,
I have been lurking for quite some time and thought I would finally post. I would like your opinion. I want to make a pair of subwoofers for a pair of Apogee Divas. What I have in mind is to use the design Apogee use for the Grand. I believe it is a pair of subs using 2x12" woofers in each sub with servo feedback. Minus the Krells of course I believe they used an accelerometer for feedback. Based on what I have read in this forum the Rythmik audio kits seem to be the go. I was thinking two dual 12" kits including the amps with servo feedback. The other option is to develop my own feedback controller and use the ICEpower 1000ASP amps I already have. Your thoughts? Cheers Matthew |
#2 |
Matthew,
Those Divas are pretty responsive, exactly what are you looking for in a subwoofer, or a pair of bass units (one for each of your Divas). You can produce the notes with a pair of sealed/ported subwoofers, but will the crossover (meaning the psycho-accoustic crossover, not the electronic one) between the 2 match? A couple of things to think about (or I fear that you will be disappointed with your first effort): 1) What about a (tall, thin) line-array of (say) 8" subwoofer drivers that would line up alongside the vertical edge of your Divas? 2) What about an open baffle or H-frame subwoofer? (Did I suggest that? It must be too early...) 3) What are you trying to achieve with these subwoofers that the Divas cannot do by themselves? Matching full-range ribbons to a subwoofer is not the easiest thing to do.
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#3 |
diyAudio Chief Moderator
I would use a couple of high Q pro drivers angled 45deg to each other's face, keeping the box I see in the pic but with no back baffle. No feedback, just your ICE and a DCX low pass. An RTA and a mic, then use the DCX parametric modules to help the room. Bliss.
#4 |
Hi Guys,
The Divas work well down to about 30-40 hz but drop off steeply due to the open baffle design. For those unfamiliar the Diva is a full range ribbon speaker. For the purists no it's not a true full range ribbon speaker but has the following: Bass - Al foil coated Kapton panel Midrange - three strips of Al foil mounted on a Kapton strip. Tweeter - True Al foil ribbon. I am more than happy with the response of the Divas in it's range but I would like something to manage the octave or two that the Diva can't do. Also doing sub 30-40 Hz will simplify the integration of the sub. The picture is not of my speakers (I wish) it just to show what the proposed subs would look like. The picture is a pair of Apogee Grands. The subs have 2x12" drivers per side with active crossovers and Krell amps. I don't want Krells (can't afford them) but I have a pair of ASP1000 digital amp modules to power the sub. I also want to consider using servo feedback. More than happy to build my own cabinets, crossovers electronics etc. Hope that clarifies it. |
#5 |
I have listened to the Divas and I haven't got the feeling of 30Hz, more like 45Hz. But that depends on the room. Wasn't big. In your case I would firstly measure them in room and then see what I need. If you can create 2x15'' open back using a DCX digital controller (affordable) plus your available amps it will be best. Only dipole bass will follow the panel seamlessly. And you NEED digital room modes control for such a performance system. Feedback will not add a real benefit and will complicate things.
#6 |
Hi!
I am a bit amazed! .... thought the Divas produced lower bass then between 40-30Hz!?I would NOT think that Your Divas i suffering from frequency cancelation in the bass region at ALL. Me myself have a pair of home made La Folia that is mostly based on the Divas in size, and I can ASSURE You that my speakers have flat frequency down to 22Hz!!! I am NOT kidding! I have tuned them myself and I have NO use for a sub on those panels. Could it be that You might have to place Your speakers a bit further from the back wall?? Just a thought. http://picasaweb.google.com/jerker.lindborg/LaFolia
The one who succeeded was the one who didn't know it was impossible. |
#7 |
Hi Guys,
Yes it could be that the speakers are placed badly but I think they are ok. Don't get me wrong they sound good. Really good. It's just that I am trying to make something similar to the Apogee Grand. The bass was much much better I have always been baffled Anyway the practice is good bass down to about 30Hz. Sure you can get some good lower response but also lots of flap. So I want to take the low end load away from the Divas (and use the sub). JarreYuri I am impressed by your efforts! How did you find cutting the Al foil and mounting it on the Mylar? And did you use one tuning point or a number over the diaphram? Cheers Matthew |
#8 | |
I see. Well I have no idea how close the foil is to the magnets on Apogee speakers, so maybee they risk flapping in high volumes. My speakers have about 5-6 mm space to the magnets and it almost goes without saying that hey are not so efficient. I use ordinary ferrite magnets (for now).One trick with the aluminium to mylar-mounting is to soap a glas table, roll out the alu-foil, take a rubber scraper and soup and make it flat and nice. Then cut it to Your liking but leave the cut-away strips. Now take some spray-glue and spray evenly over the entire surfice. Take the mylar and stretch it over a padded plywood or similar. Spray the mylar and NOW carefully remove the cut-away strips. Now You dont have any glue on the glass. Place the stretched mylar on the pre-glued alu-foil and then remove the paded playwood. Now take a rubber roller and roll over the mylar to make it get good and even contact with the alu-foil. Then carefully remove the whole membrane unit from the glass table. Here is a link to a person I just bought some new treble-ribbons from. He corrugates them very nicely. http://www.dahlbergaudiodesign.se/del1/del1.htm
#9 |
PS. Yes, I used multible resonance points to tune the membrane.
#10 |
Awesome stuff! Nice link too.
A great place for ribbons is www.apogeeacoustics.com Graz sells all of the Apogee spares and can do custom jobs. Really nice kit. I am probably heading off topic for a subwoofer forum so I would be happy to email about the ribbons if you want. Cheers Matthew |
| (first) subwoofer project | jumpus | Subwoofers | 6 | 20th May 2007 07:52 PM |
| My 1st Subwoofer project | gmilitano | Subwoofers | 11 | 9th December 2006 05:39 AM |
| subwoofer project, which subwoofer? | Davlaf | Subwoofers | 12 | 9th November 2006 03:59 AM |
| to all the switch mode power supply divas | mikechamboko | Power Supplies | 1 | 1st March 2005 08:24 PM |
| Subwoofer project | rabbitz | Subwoofers | 2 | 21st July 2003 02:03 PM |
| Page generated in 0.13094 seconds (83.68% PHP - 16.32% MySQL) with 11 queries |
