Old 13th August 2007, 11:36 PM   #1
Default Using phono input with PLLXO
I am planning to experiment a bit with PLLXO for a subwoofer that will be running from 40Hz on down. I will probably try 2nd order 1st.
It occurs to me that it might be advantageous to use the phono input on the amplifier that will be powering the sub. My thought is that the several dB per octave slope in this region could help partially compensate for the roll off of the subwoofer and the extra gain of the MM phono stage could help with losses in the passive filter. If the gain is too high I could always pad it down. Another advantage is that the low pass above the 40Hz cut off would be of slightly higher order than if I used the regular aux inputs.
Any reason that I should not try this? I realize that there may be a sub 20Hz high pass in there too but that might not be all bad.
mike
Phono input selector switch Woodsong Audio Analogue Source 21 6th March 2010 04:19 PM
6C45 phono input only? mashaffer Tubes / Valves 3 2nd January 2009 12:34 AM
Phono input usable for other components? camusmuse Analogue Source 21 11th December 2005 09:32 PM
Phono Pre-Design Input philipbarrett Tubes / Valves 22 5th November 2005 04:20 PM
Can you explain? Phono amp input stage rsrphotos Solid State 6 9th August 2004 05:50 AM
Page generated in 0.05851 seconds (65.84% PHP - 34.16% MySQL) with 10 queries
