Need to replace Tempest with possibly 2 15" Dayton RS HF
Old 10th August 2007, 06:12 AM   #1
JeffKnob is offline JeffKnob  United States
Default Need to replace Tempest with possibly 2 15" Dayton RS HF
I currently have an Adire Tempest in a 194L enclosure with 2 PR15 passives. This was built according to Adire's plans for the SBB4 enclosure. The Tempest now has some tears in the surround. I have heard that with this sort of damage, it is very important to get this fixed because it could lead to damage to my amp as well. I know the Dayton DVC would be an almost direct replacement. I was however thinking of changing the whole setup to get some tighter sound while still using the same enclosure.
I have used WinISD and the Dayton RS 15" HF look great if I were to put two of them in this enclosure. The curve doesn't seem to change much except go up if I use 3 of them. The enclosure I have has a 15" hole on opposite sides and on the bottom. To put 2 of them in there I will just seal up one hole. Would it be best to mount the two on each side and cover the bottom hole or mount one on the side, one on the bottom and cover one on the other side?
Old 11th August 2007, 04:53 PM   #2
crippledchicken is offline crippledchicken  United States
crippledchicken's Avatar
http://www.acoustic-visions.com/~aco...mpest_classic/ is this the driver you need? for exact, replacement
Old 11th August 2007, 07:18 PM   #3
I am not looking for a direct replacement however. I would like to change things up a little. I guess the big question is whether I should mount the drivers on opposite sides or one on the bottom and one on the side.
Old 13th August 2007, 07:43 PM   #4
owdi is offline owdi  United States
owdi's Avatar
Mounting them on opposite sides will make the whole thing vibrate less.
Dan
Need to replace Tempest with possibly 2 15" Dayton RS HFHide this!Advertise here!
Anyone possibly have plans for the "Spires" around? Loading17 Multi-Way 20 23rd June 2009 07:47 AM
Which driver 15" dayton RS or tempest x saabracer23 Subwoofers 11 7th October 2007 06:51 AM
2 x TC2+ 15" subwoofers for sale (possibly 4) and mint Crown K2 amplifier taloyd Swap Meet 6 4th May 2007 03:30 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Tempest 15" or Dayton 15" DVC Sub? longblock454 Subwoofers 1 31st January 2004 06:24 AM
Copyright ©1999-2017 diyAudio
