Old 8th August 2007, 03:32 PM   #1
Default Another tapped "horn" ?
I don't know it the following topology was already discussed anywhere and if it is useful at all.
Enclosed you will find a drawing of what I came up with.
The walls do not necessarily have to be parallel of course (i.e. the path may be tapered).
The intended principle is that the red part of the path works as as lambda/4 resonator at the upper cutoff frequency - whereas the green part acts as lambda/2 phase delay at this frequency. At the lower cutoff frequency the whole path length would work as lambda/4 resonator.
I am convinced that it would somehow work the way it is intended to at said frequency extremes - although I am not sure how well. And I am completely unsure how it will act between those frequencies. Maybe there will be not output at all or very peaky or whatever.
Charles
Old 8th August 2007, 05:03 PM   #2
freddi is offline freddi  United States
freddi's Avatar
Hi Charles - did you try simulations in Hornresp?
Freddy
Old 9th August 2007, 07:20 AM   #3
No, I didn't. I did not use hornresponse at all so far.
Maybe worth a try.
Charles
Old 9th August 2007, 09:49 AM   #4
OK I downloaded the program and made a few tries.
Very cool and almost self-explanatory if "classical" horns are to be simulated !
But I can't select the "tapped horn wizard" , i.e. there is no way to get this selection highlighted.
What do I have to watch out for ? I set up a flare with conical sections and no back chamber but I can in no way get the "wizard" highlighted.
Charles
Old 9th August 2007, 05:45 PM   #5
GM is offline GM  United States
GM's Avatar
Well, when you follow the driver/horn input instructions it will ask you if you want to model a tapped horn when you click 'calculate'........
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th August 2007, 08:20 PM   #6
Default Those ideas are stolen by the past...
take a look at Arnold Klayman's US patent # 5,177,329 in particular Fig. # 2.
http://www.google.com/patents?id=0oc...ayman,+5177329
moray james
Old 9th August 2007, 08:38 PM   #7
Post Re: Those ideas are stolen by the past...
Yes nice, just had a look, its got nothing to do with a horn, i thinks its similar to a ported enclosure, there we resonate the port here to have a huge chamber to resonate instead, will give max 3db gain as ported systems do, i dont think this is an effective or usefull design
am i thinking right ????
Old 9th August 2007, 08:51 PM   #8
Default Klayman's drawing shows...
duct with straight sides however a taper could also be used. First drawing is a 1/2 wave device with the second using half and 1/4 wave lines. The similarities to a Tap design are obvious. Remember 1/2 wave length is where a horn gets efficient. These designs are said to be very powerful with a number still in use today.
moray james
Old 10th August 2007, 03:09 AM   #9
zobsky is offline zobsky  India
zobsky's Avatar
Charles
Neither can I
The program just takes me direct to the calculation results. I' m sure I'm forgetting something, ..but what is it?
"Any fool can know. The point is to understand" - Albert Einstein
Old 10th August 2007, 04:31 AM   #10
GM's Avatar
Hmm, guess I misunderstood the Q.......... click the EDIT button and now the Tapped Horn Wizard is highlighted. See HELP pg. 9.
Dual 8" tapped horn = TH-SPUD geitmans Subwoofers 119 1st January 2012 09:14 PM
Tapped Horn for 18" bass angeloitacare Subwoofers 14 28th March 2009 08:37 AM
Grill Material for Stan White "Curled" Horn Reproduction rlabomb Multi-Way 0 26th May 2008 03:24 PM
Data of Isophon DKT11 "Exponential-Hochtonstraler", treble horn peranders Multi-Way 3 10th December 2002 09:13 AM
Page generated in 0.11619 seconds (85.04% PHP - 14.96% MySQL) with 11 queries
