I would like to know if anybody has compared these two together. I am building Zaph BAMTM and was thinking of using TB, which is cheaper. Responses are highly appreciated. Jetty2 |
#2 |
I have not used either of these, but I do have 4 of the RSS315HF, the big brother to the RSS265HF.
The primary difference between the drivers would be the lower non-linear distortion of the Dayton motor. The RSS series have very low distortion and have well designed motors. The Dayton has 14mm xmax, compared to the TB's 9.5mm, but you probably won't need all that xmax anyways. The Dayton has a cast frame, the TB is stamped steel. Not the biggest issue, but the Dayton would likely have less mechanical noise at high excursions. Claimed efficiency is similar, but I would not put alot of weight into comparing efficiencies amongst different manufacturers. When you get down to it, they are very different drivers. The TB has one very interesting feature and that is it's shallow mounting depth. If this feature is not needed, I would not recommend it over the less expensive and (likely) lower distortion Peerless SLS 830668. Available at Madisound. Which brings me to my recommendations. For a good, inexpensive, low distortion woofer the 830668 is a good buy. If you are trying to stay at the partsexpress website for the free shipping, and aren't as concerned about the distortion, I've used the 10" Quattro QT255-4 with good results in the past. It's on special for $50 right now. I'm not saying that the TB is a bad woofer. I just think that you pay a premium for the low mounting depth that could be spent on a higher quality woofer if the depth is not an issue. Best Regards, David |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| Tang Band W5-704D + Dayton PT2C | 69stingray | Multi-Way | 12 | 4th March 2008 02:23 PM |
| Tang Band WT-1427B 10" Neo Subwoofer | JimOfOakCreek | Swap Meet | 5 | 28th February 2008 07:27 AM |
| My Tang Band WT-1427B Project | JimOfOakCreek | Subwoofers | 2 | 7th February 2008 09:27 PM |
| Dayton RSS265HF-4 | 4real | Multi-Way | 7 | 21st September 2005 06:15 AM |
| Page generated in 1.20745 seconds (-83.21% PHP - 183.21% MySQL) with 10 queries |
