Old 6th August 2007, 04:30 AM   #1
Send a message via ICQ to phreeky82
Default Odd port shapes/configs
I'm using winisd to calculate sub box stuff, and would like try and idea of using a port that slowly goes from a small opening (inside the box) to a larger opening on the outside.......so, tapered at a shallow angle to give minimal turbulence without needed a mega-long port.
It will be a slot style port, not round.
If it, say, starts out at 20mm high, and goes out to 40mm high at the exit, will it be the equivelant of a 30mm port all the way (assuming constant width)? In practice does this simple calculation work?
Any other "tricks" I should consider?
Old 6th August 2007, 10:22 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
phreeky82:
...so, tapered at a shallow angle to give minimal turbulence without needed a mega-long port….It will be a slot style port, not round...In practice does this simple calculation work?…
No it won’t, your assumptions need a better understanding of port slot profile acoustics. See at the links at:
http://www.diyaudio.com/forums/showt...62#post1054262
or:
http://www.lam.jussieu.fr/src/Membre...rin_polack.pdf
http://www.lam.jussieu.fr/src/Membre...inAES116th.pdf
I also rec. you to read the AKAbak manual at page 178 = ‘Duct’ considering the choice of port cross sectional areas.
A picture of successful implementation of slot profile ports (as in fig # 5 (AES 112th) page 3) in use (tuned to 40 Hz/ 9 Litres/driver box for 7 Seas P14 RCY in a horizontal row) can be found here:
http://www.diyaudio.com/forums/attac...amp=1177625327
b
1(1)
Old 6th August 2007, 10:57 AM   #3
Cheers, some of that looks like interesting reading.
I wanted to put something together relatively quickly and reliably (i.e. i don't wanna experiment too much for this project), so I'll go with simple port for this box and maybe dive into that stuff for some test boxes in the future.
visio shapes desmondmonster Tubes / Valves 4 13th January 2009 07:30 PM
Got horn shapes on my mind gnugear Full Range 19 11th April 2008 04:44 AM
Different speaker shapes Johnny25 Full Range 16 10th February 2006 03:29 PM
Graph shapes Danielb Multi-Way 9 3rd November 2004 12:26 AM
Are you looking for suggestions for enclosure shapes? kneadle Multi-Way 4 2nd March 2003 02:42 PM
Page generated in 0.06975 seconds (73.00% PHP - 27.00% MySQL) with 11 queries
