Old 10th January 2012, 04:28 PM   #21
TheGimp is offline TheGimp  United States
TheGimp's Avatar
If that voltage is when it is disconnected from the amp, then it is normal. The adapter has a high output resistance, which when under load drops the voltage down to the specified 18VDC.
If that measurement is with the amp connected and running, then it is probably too high.
Old 10th January 2012, 11:19 PM   #22
flux55 is offline flux55  Canada
Thanks Gimp. That was a no-load reading from the power supply. I'll check that off the list of possible causing problems. Will now focus on those capacitors as the probable problem.
Old 11th January 2012, 10:08 PM   #23
nigelwright7557's Avatar
Be careful if you fix your amp before checking the speaker.
Sometimes a blown amp will fry the voice coil.
Then applying power from your fixed amp will blow it again !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 12th January 2012, 07:08 AM   #24
Thanks Nigel for this extra warning. I'll compare the Ω readings of each speaker and check for shorts.
Old 3rd February 2012, 12:31 AM   #25
Smile Overheating & Hum FIXED
Thanks to PSHITNIS I fixed this problem for ~$5. First I like to say I know very little regarding electronics. But I'm good at following instructions. Ordered those capacitors from ebay. Over 3-weeks shipping time from Hong Kong. I'm on a tight budget, so this was worthwhile. Kudos to pshitnis.
Stuck on Standby CSlee Tubes / Valves 16 20th March 2009 05:19 PM
Stuck in a dip ttruman Multi-Way 77 6th June 2008 12:51 PM
Amp stuck on audiobahnkid592 Car Audio 1 8th July 2007 11:31 PM
cd stuck in nakamichi cp-1 agiff Digital Source 3 6th July 2005 07:03 PM
Page generated in 0.08292 seconds (76.99% PHP - 23.01% MySQL) with 11 queries
