Old 3rd August 2007, 11:42 AM   #1
Exclamation Help with crossover for Sub
hi
i need to make a passive crossover for 100rms sub, that means i will put 25volts across the sub at max
cross over freq arounf 80hz
Should i go for 1st order or 2nd order or 3rd???
which type of capicitor will have high capicitance close to 300uf and still withstand 25v and that too without any polarity issue(non-electrolytic) ????
is it easy to find a 8mHy inductor ??? or is it toooo much???
or passive cross over at such low freq is very difficult????
Old 3rd August 2007, 12:08 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Difficult and expensive. Not really ideal, active would be far superior, 4th order is easily attainable this way. Even with a seperate amp (plate amp would do, many have filters built in) active will likely be cheaper.
Old 3rd August 2007, 12:47 PM   #3
Talking thanks
i went for passive coz i wont be able to find much time for soldering making PCB, i am elecronics engg. but i work in IT sector and dont have much spare brain cells to kill for non working circuits, sir do u have any simple easy idea or ckt or any small IC for makin a filter
can u gimme any directions for a simple least soldering active filter that can be assembled with use of any PC oscilloscope n signal gen. s/w
thanks a lot for ur previous responce
Old 3rd August 2007, 12:50 PM   #4
Did it Himself
richie00boy's Avatar
I have a sub controller on my website www.readresearch.co.uk, I'll be updating the project soon to show the component values on the PCB. You don't need a PC or oscilloscope to do it
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th August 2007, 04:01 AM   #5
OzMikeH is offline OzMikeH  Australia
If you REALLY want to go passive. I expect it will cost you about $1 per uF for bulk good quality caps if you don't get lucky. Then you have to solder them all together into a bigger capacitor or just buy a pre-made plate amp.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 01:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.07731 seconds (75.49% PHP - 24.51% MySQL) with 10 queries
