PE Bash 500 Amps shut down problems?
Old 2nd August 2007, 08:44 PM   #1
crippledchicken is offline crippledchicken  United States
crippledchicken's Avatar
Default PE Bash 500 Amps shut down problems?
anyone else use this amp and have problems with it shutting down often? HT is where i have the problems and, according to the reviews on PE site, i'm not the only one. i guess that's why they come with rumble filter set at 30hz stock? guess they have no power at lowest frequencies. any thoughts? Thanks!
Old 4th August 2007, 08:21 AM   #2
phillip_f is offline phillip_f  United States
sorry, i have one but it's still in the box. i'm planning on using
it to power a lab12 in a tapped horn, but as i just sank a good
bit of time into building altec 2-ways, the subwoofer will have
to wait a bit.
i read the sheet that came with the amp. did you change the
filter frequency, and if so, to what?
Old 6th August 2007, 12:29 PM   #3
hi Phillip, i changed r17 to 20k and r18 to 75k. if i remember right, this gave a boost of 1db 25-30hz and filter of 18.7hz instead of the factory value of around 30hz. good luck with your project!
PE Bash 500 Amps shut down problems?Hide this!Advertise here!
Boost in BASH plate amps.. JandG Multi-Way 2 16th March 2016 07:04 AM
FS: BASH 300W subwoofer plate amps $75ea. NIB awedio Swap Meet 8 28th October 2009 05:28 PM
Bash chip amps thylantyr Chip Amps 16 18th November 2006 05:06 PM
Car US AMPS USA-1000x with problems odiepsock Car Audio 3 21st July 2006 03:58 PM
replaced cd player op amps, various problems now dvdwmth Digital Source 7 27th November 2004 02:42 AM
