Hello,
a new idea, sub for 6,5" - 8" bass driver, wall or corner standing, 30% transparent by making the triangle front and back wall in acryl 25 mm, horn mouth side wall glueed with a mirror combine with a lamp will get a new look. also possible to use the sidewalls for books, CD etc. top on the magnet a climbing plant and you will in short time "never" realize that´s a bass box.
http://www.hm-moreart.de |
#2 |
the diagram was a bit tough to understand but nice,
i'll build one horn enclosure for sure in a year or 2, i think making a horn out of a bed or a table would give a lot of volume and a decent look BTW can i use ordinary transparent window glass instead of acryl 25 mm with a small driver .... PS.. climbing plant, with all that basss n boom plant on will surely rock |
#3 |
Hello,
look better: http://www.hm-moreart.de/95.htm To get holes in the glass is expensive, in my case normal glas would work but min. 10mm thick.
#4 |
Hi HM - nice looking basshorn - so path goes ~2 turns?
will Alphorn work fullrange with some 20cm driver? Best wishes, Freddy |
#5 |
Hello Freddi,
no, it will get at 150 Hz to loud. only 90-100 Hz 18 dB aktiv is a good solution, bass boost is in 20-25 sq m not necessary, a small sub modul is enough.
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.10283 seconds (73.25% PHP - 26.75% MySQL) with 11 queries |
