Old 30th July 2007, 02:54 AM   #1
Default subwoofers dont *boom* at the same time
I have two subs in one box that do not bump at the same time.. i hooked them up separately and one sounds just a little big louder than the other.. any ideas?
Old 30th July 2007, 03:32 AM   #2
OzMikeH is offline OzMikeH  Australia
Your question is like saying " I put a turbo on my truck but it drives funny, why?"
Is it any old speakers in any old box or was it properly designed?
If the former then the news is bad: you need to take it apart, learn about it, think about it and start again before you break something. No-one can help you if it's just random junk thrown together. Have a look at the Wiki section of this site to learn some of the basics, If you do some of your own legwork people will be very happy to help you learn. You might have some really good junk that just needs the right cabinet or you might be better off using the drivers to stick the shopping list to your refrigerator.
If the latter you need to provide a lot more information. Internal dimensions of the cabinet, port dimensions, Driver T/S specs, what filtering you are using to drive them, where in the room it is, how big is the room?
Old 31st July 2007, 09:24 AM   #3
They aren't a bunch of junk put together.. i got the whole set and they used to hit at the same time and everything worked great.. just recently they have stopped hitting at the same time and i have no idea why the sudden change.. do u kno why this would just happen?
Old 31st July 2007, 10:04 AM   #4
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Hi xJ2daO2daNx,
Have you checked woofer voice coils with an Ohm meter.
Maybe one woofer VC is open and that woofer now acting as a passive radiator.
/ Anders
Old 31st July 2007, 05:02 PM   #5
theAnonymous1's Avatar
Default Re: subwoofers dont *boom* at the same time
Dual voice coils in parallel ehhh?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 31st July 2007, 06:54 PM   #6
how would you fix it if one of the voice coils is stuck open?
Old 31st July 2007, 07:02 PM   #7
The only way to fix it is to recone the driver. Unless it is a high end driver it probably wouldn't be worth it.
If one of the coils is blown, then the only thing you can really do besides getting a new driver is to disconnect one of the coils on the good driver so they play evenly.
Old 31st July 2007, 07:42 PM   #8
Enjoy good sound
AKN's Avatar
Oops, I did obviously not read your first post carefully enough. My assumption was that you had not tested woofers separately, sorry for any confusion.
But if you have dual VC woofers you could have one of the VC's open as suggested by theAnonymous1.
Do you have dual VC woofers?
What kind of woofers do you have?
You could also have some shorted turns in the voice coil of the woofer that has the lowest output. (This applies whenever you have dual or single VC woofers.)
Check Re of every coil with a DVM and confirm that the values are fairly close and that no VC is open circuit.
/ Anders
Hi-Fi Stereo went BOOM nfm Parts 33 4th September 2009 02:26 PM
trick behind the boom box ravslanka Subwoofers 13 17th January 2009 10:46 PM
best boom for the buck? peace brainerd Subwoofers 10 15th December 2005 09:56 PM
Kenwood KAC 820 Amp went Boom! sidskiba Car Audio 8 3rd December 2004 05:58 AM
R/Boom correction timolien Multi-Way 1 7th July 2003 02:38 PM
Page generated in 0.09248 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
