Can any one tell me wats the world highest sensitivy sub, just sub only without horns
well i found this JBL P1222 which sayz 97dB SPL @ 400rms aprox350$ http://www.jbl.com/car/products/prod...at=SUB&ser=POS i guess its one of the most efficient n highest SPL i have ever seen in spec. of any sub Have u seen anything better than this... |
#2 |
That sensitivity is most likely derived from the two 2ohm coils in parallel - so, a 1 ohm load. Also, it's not referenced to 1 watt - but to 2.83v.
The real spec at '1 watt' is probably much much less.
Crazy Yankee. |
#3 |
The highest I've seen was the Aura 1808's ~98 dB/W/m measured some years ago, but no longer made AFAIK.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 | |
], not a fair thing
#5 |
http://www.precisiondevices.co.uk/showdetails.asp?id=16
![]() And of course, all the less significant out there. Just to name a small few.. http://www.usspeaker.com/eighteensound-21LW1400-1.htm http://www.usspeaker.com/beyma%2018LX60-1.htm http://www.usspeaker.com/beyma%2021L50-1.htm http://www.usspeaker.com/EVX%20180B-1.htm And let's not forget some of the 24 inchers!.. http://www.precisiondevices.co.uk/showdetails.asp?id=17 http://www.atomicspeakers.com/ele24.html ^ Atomic ELE24 is only a measly 95.3dB and dual 4 ohm, but with 19.6Hz Fs and 15mm Xmax though. ..I guess this is all different though. I think I've seen quite a few claiming over 100dB too, with response graphs (as if that really means anything). |
#6 |
Here is a company that has some Ciare HW450 to give away for an intersting price:
http://www.sas.co.at/verkauf.htm Here are the specs: http://www.ciare.com/pdf/catalogo/HW450.pdf |
#7 |
A pair of those hw450s in a cabinet would make a nice "little" sub speaker.
About 104db/2.83V/m will make a bit of noise around the neighbourhood.
regards Andrew T. |
#8 |
I was mighty impressed by the 97dB of the JBL, but then I realized it is 2.83V at 2Ohm, so you have to subtract 6dB.
#9 |
Speakerholic
That Ciare looks like nothing more than a lightweight PA woofer. Anything but a "sub". Down 20 dB at the 25Hz Fs.
#10 | |
From the bottom of the page in small blurry print
| driver sensitivity vs system sensitivity | bvan | Full Range | 12 | 5th November 2007 07:57 PM |
| Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? | rhythmdiy | Multi-Way | 5 | 5th November 2007 11:33 AM |
| typical sensitivity of powered subs? | capslock | Solid State | 0 | 13th April 2007 07:42 AM |
| Convert floor standers to subs with Tang Band 8" subs? | prerunnerv6 | Subwoofers | 3 | 26th February 2006 12:44 AM |
| Highest Quality 2-way | amirmk | Multi-Way | 52 | 23rd August 2005 10:01 PM |
| Page generated in 0.10988 seconds (73.74% PHP - 26.26% MySQL) with 10 queries |
