Old 21st July 2007, 01:30 AM   #1
JinMTVT is offline JinMTVT  Canada
Default 4 21" for HT ..what u think ?
http://www.tr.ca/2006/english/produc...s/nac-221.htm#
local company ...want to encourage them
planning on my HT system for a completely treated and controlled non rectangular 20' by 25' room ..
would get 2 of those ...i know that Belisle accoustics produces high quality drivers ..wonder if anyone has any experience with their complete sub boxes
would be used for <100hz
probably 70-80hz crossed pretty steep to
some 24 8" mids in stereo line array for front ..
1 box of 2 21" on each side for stereo bass
Old 21st July 2007, 01:36 AM   #2
also,
how would you recommend fixing those monsters to the house ???
my house will be made with ICF ( concrete covered with isolated foam forms )
i dind't plan any finish for the HT room yet,
as it is the least of my concerns
( i usually turn the lights off when i watch a movie neway )
i am not sure how i could fixe those so they don't vibrate on the floor/walls ...
Old 21st July 2007, 02:16 AM   #3
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
bolt 'em to the walls of the house,
enclosures outside-
18
Old 21st July 2007, 03:49 AM   #4
enclosures outside ? i hope that you don't mean outside of the house!
the outside of the enclosures to the house walls ok ?
directly on the foam would do or too soft ?
if i know in advance
i'd probable be able to put some anchors directly in the concrete
Old 23rd July 2007, 03:50 PM   #5
Speakerholic
Cal Weldon's Avatar
Default Re: 4 21" for HT ..what u think ?
Hmmm...that's over 16' tall with the enclosure.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th July 2007, 07:53 AM   #6
Lindell is offline Lindell  Sweden
hmm.... an almost 800 liter cabinet playing "only" to 29Hz. I bet they measure -5db or more. Max SPL 146 db!
Why in the hell do you need that level in your living room?
Sure, let them endorse you with a pair.....but make sure to get them for free...
Old 24th July 2007, 07:55 AM   #7
Looks like they're using these woofers:
http://www.precisiondevices.co.uk/showdetails.asp?id=16
Old 24th July 2007, 09:21 AM   #8
Yep. Maximum flat response for a vented enclosure is about 2.75 cubic feet @ 47Hz for an F3 at 56.3Hz, LOL.
For that kind of money, there's many more suitable options out there for this application, to say the least..and that's putting it mildly.
Old 24th July 2007, 10:26 AM   #9
Why not a hugh tapped horn with 4 B&C 18TBX100?
You could easely get flat respons down to 18 Hz and a max SPL of 135 dB @20 Hz
We live in a horizontal world, why use vertical topologies???
Old 24th July 2007, 08:32 PM   #10
hooha is offline hooha  Canada
hooha's Avatar
Indeed. You can do way better with less...
Breaking speed records - http://www.mach5audio.com
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.09703 seconds (81.79% PHP - 18.21% MySQL) with 10 queries
