Old 17th July 2007, 04:10 AM   #1
Tino is online now Tino  Canada
Default Vifa M26WR-09-08 10" drivers
Anyone build a really nice sounding sub with these? I have a pair I had purchase AGES ago but never got around to really building a cabinet for them. Its now 10 years later or more and I'm going to get around to it. They are dusty but everything still in good shape.
I will be powering the subwoofer with a soundcraftsmen 205wpc power amp running stereo and it will be electronically crossed over at 70Hz (18db/oct) from an Audiocontrol Phase Coupled Activator - for anyone that remembers this stuff
Not sure how a properly built sub would sound driven off an amp like this with an outboard crossover vs a pre-made sub with a plate amp but I've got this stuff already so maybe make use of it. The goal is sound quality as opposed to high volume.
This driver seems to prefer a vented enclosure over a sealed at least looking at the specs but I wonder if going with a sealed cabinet anyway might give me better control and extended bass response (at the sacrifice of bass volume of course)....
The sub will be complimenting a pair of bookshelf speakers I built with a Vifa 6.5" and 1".
....so whats the thoughts on this sub. Is this a good driver to start if I want good clean bass?
Old 17th July 2007, 11:21 AM   #2
They suit around 30L / 1 cuft sealed or double 60L / 2 cuft vented.
For vented I'd recommend a tuning frequency of around 26Hz.
Two subs, ~ 1/3 across back and side wall will sound smoother.
Vented will go louder, probably not need EQ in room.
Sealed, I'd add a 2nd order high pass, Q=2, ~ +6dB boost @ ~ 30Hz.
You could consider a single vented isobaric also, ~ 30L.
/sreten.
Old 17th July 2007, 12:34 PM   #3
/sreten.
Old 17th July 2007, 02:42 PM   #4
Fantastic. Thanks Funny, my calculations were not too far from that. I worked out a box of 2.13cf (vented) and a tuning of 27Hz (which is the same as the FS roughly...not sure if thats bad or not).
So if it was you and the listening room was only 10'x12', would you go with the sealed cabinet or the vented? I guess I could make both and try it. Its only wood and some time
Old 17th July 2007, 02:43 PM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
It's a great driver for a music sub and there is a member here that built them in an isobarik (I think) using push-pull.
I can't remember the details but the box was oversized, ported and they sounded great. Do a search for posts by barfind.
Old 24th July 2007, 08:23 AM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
rabbitz:
It's a great driver for a music sub….
Agree…
Tino:
Look at my comments at:
Sealed box size for Vifa M26wr-0908 .?
Submitting a new simulation, close to a ported Bessel alignment in a 59 L (2.084 cu. feet) box or with a closed port, a Qtc very near a second order Bessel is achieved, in my opinion both very good choices for use as ‘musical subs’ and stands for your bookshelf speakers.
b
1(2)
Old 24th July 2007, 08:24 AM   #7
2(2)
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
ACI 12" sub drivers (2), Vifa 8" poly (4), North Creek D26 tweeters (2) nodiak Swap Meet 2 29th October 2007 03:45 AM
FS: 2 new Vifa M26WR-09-08 10" woofers in Oz rabbitz Swap Meet 1 30th January 2007 12:55 AM
Sealed box size for Vifa M26wr-0908 .? JandG Subwoofers 5 12th November 2006 03:41 PM
Enclosure size for Vifa M26WR 10" The Paulinator Multi-Way 7 21st December 2003 05:46 PM
Page generated in 0.10449 seconds (79.75% PHP - 20.25% MySQL) with 11 queries
