Old 15th July 2007, 08:59 PM   #1
HTRookie's Avatar
Default ADA1200 Application Query
I have had the ADA1200 for some time, intending to use it with my Avalanche 18. As is unlikely that I will proceed with that project, would it be unwise to use it with my work in progress Peerless 12" XLS/Dual PR sub? I will keep the gain turned down... saves buying another plate amp....
Thanks for any advice
HTR
Old 16th July 2007, 04:51 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi Bruce,
Another woofer in the works? Good news.
I see no reason why you couldn't use it. Big amps are better than small amps.
I have some new things for you to look at. We should get together in a couple weeks when the rest arrives. Great big stuff to go with the other great big stuff.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th July 2007, 12:42 AM   #3
HTRookie's Avatar
Default Together
I shall get in touch with you in a few weeks then Cal.
With any luck, my new subwoofer will be done by then. I am now working on my HT room, finishing the sound insulation, and then on to the wainscotting/drywall/paint. All that is left speaker-wise is to build the mains/centre channel, pick a side/rear surroud design, build them..........
Bruce
Adire ADA1200: Are they Lemons? HTRookie Subwoofers 0 17th June 2009 07:28 AM
UK Law query john blackburn The Lounge 35 15th May 2009 09:59 AM
fs ada1200 chainenoble Swap Meet 1 5th March 2007 09:29 PM
My Adire ADA1200 has got a problem BassAwdyO Class D 15 6th February 2006 09:22 PM
AGC for PA / SR application AudioFreak Solid State 4 13th February 2004 09:13 PM
Page generated in 0.06025 seconds (73.50% PHP - 26.50% MySQL) with 10 queries
