Old 10th July 2007, 07:35 PM   #1
asiquis is offline asiquis  Canada
Default Ideas as to what is inside? Need 16Hz for digital pipe organ-help?
http://www.ttechcorp.com/e3.htm
To design a world-class speaker, we broke from the conventional wisdom in the following aspects:
(a) we used very low-mass woofer cones and large magnets for superb damping, a design choice that normally conflicts with the goal of extreme low-frequency output amplitude,
(b) we employed active equalization to make up for the loss in low-frequencies resulting from low-mass cones (we ruled out passive equalization due to waste of mid-range power from the user's amplifier),
(c) we employed two such cones (i.e., two separate woofers) each having a 15 inch diameter, in each speaker cabinet, to handle the boosted signal power produced by the equalization,
(d) we planned the use of the PRESTANT - I system as a pair (which reduces 2nd harmonic distortion by 50% and 3rd harmonic distortion by 75%), although magnificent performance is possible using just one of our speakers, and
(e) we took a cue from the design of the prestant organ pipe, and constructed our low-frequency cabinet to have a mouth at the bottom (another subject of extensive computer analysis), and we consulted organ builders about how to prevent resonances, buzzes and rattles in the cabinet, and
(f) last but not least, we commissioned an award-winning furniture designer to build a cabinet as beautifully unique in its esthetics as it is in its acoustic properties.
Like a prestant organ pipe, our speaker's mouth is tuned. Magnificent walnut veneer is used for the exterior cabinet surface. The cabinet walls are all one inch thick and secured using proprietary techniques. The mouth of the system is part of an "S" shaped duct that divides the interior of the cabinet into three chambers. The bottom chamber, opening to the acoustic environment via the mouth, uses the floor as one of its walls. Thus, one can actually feel the pedal notes of the organ, or the bass drum in a symphonic work.
We discovered after our first design that any listener could hear the superiority of the result. Still, we weren't satisfied, because in the initial design, response was flat (without equalization) only down to 28 Hz. After a revision to the design, and the addition of active equalization, and still two more revisions to optimize the equalizer design, we were satisfied. Never before have we as music lovers been so pleased with the sound of electronically reproduced music. And we discovered that when it sounds right for pipe organ music, it sounds right for everything else. Most speaker designers would have stopped with a design employing a single small 12 inch woofer, falling far short of even our rejected first-pass attempt. Their designs strain unsuccessfully to reproduce the bass drum sounds in Stravinsky's "Rite of Spring" (compare theirs to ours while auditioning Leonard Bernstein's version with the Israel Philharmonic on Deutsche-Grammophon compact disc # 431 045-2).
Large-cone woofers are used in our system because, although frequency response at small signal levels (low loudness) can be addressed by smaller woofer diameters, at high loudness these smaller speakers can do little but flap and flutter their cones in a frantic frenzy. The use of large cones provides movement of sufficient air to sustain the loudness of pipe organ pedal sound in a home listening environment.
Old 10th July 2007, 07:44 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default What's inside?
The pricelist reveals "2EA 15 inch drivers" for $3000.
Apart from that, mostly air.
/Hugo
Old 10th July 2007, 09:32 PM   #3
auplater's Avatar
Default Re: What's inside?
/Hugo
...probably "warm" air at that, eh???
John L.
"...His brain is squirming like a toad..." Jim Morrison
Old 12th July 2007, 08:57 PM   #4
tade is offline tade  United States
Send a message via AIM to tade
wow
Old 12th July 2007, 10:14 PM   #5
Cloth Ears's Avatar
Default Re: Ideas as to what is inside? Need 16Hz for digital pipe organ-help?
Originally posted by asiquis
To design a world-class speaker, we broke from the conventional wisdom in the following...
...use of large cones provides movement of sufficient air to sustain the loudness of pipe organ pedal sound in a home listening environment.
If you're going to post on a DIY site, should you not provide some more detail - otherwise, you should be posting in the Vendor's Bazaar Forum. How about:
1) Which EA drivers (and point to a link with the details)?
2) What active equalisation and what circuit you use for this?
3) What amplifier are you using to drive this (and maybe a circuit if it's your own design)?
4) What box alignment are you using (details)?
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 12th July 2007, 10:36 PM   #6
Sonusthree's Avatar
Default Re: Re: Ideas as to what is inside? Need 16Hz for digital pipe organ-help?
I don't think he's the maufacturer/designer/vendor. He's trying to find "Ideas as to what is inside" and wants us to help.
Anyway ......
Why do you want to emulate this design in particular?
Is it a subwoofer for a Hi-Fi setup?
What SPL do you need (volume)?
You want it to do 16Hz but how high will it need to go?
Do you want accurate? .... or just efficiently powerful?
What are your space constraints? (Bigger is generally better for low frequencies.)
Tell us more ..... and welcome to the forum,
Martin
Martin
Old 13th July 2007, 12:09 AM   #7
Cloth Ears's Avatar
Default Re: Re: Re: Ideas as to what is inside? Need 16Hz for digital pipe organ-help?
Ulp! My apologies, asiquis. I jumped the gun a little.
My first attempt with this is to mail the appropriate party, in this case ttechcorp@earthlink.net is on their website. You'd be surprised (sometimes) how much info they will sometimes release to an individual.
I'm probably with Martin in that you needn't necessarily look at a particular manufacturer (excepting in the looks department - they do look nice) with regards performance. For what you may be wanting, size is generally all that is required - how much depends on your wants and your budget.
My suggestion, if you can stretch it, is that a sealed box (unlike the one you posted) would provide more accurate sound, but would probably be a bit more expensive to implement. But, that is my opinion...
Again, my apologies.
Jont.
Old 13th July 2007, 03:09 AM   #8
Default see William Cowan's page...
The 18 Hz horn will do a solid 16 Hz using two 12 inch Peerless woofers.
http://diy.cowanaudio.com/index.html
moray james
Old 13th July 2007, 02:23 PM   #9
Default 16 Hz subwoofer insides clarification!!
I was unclear with my post.
Thanks for those-Sonusthree/Martin- that figured out what I was trying to ask. I am not the designer of the Talbot tech Prestant-I subwoofer. I was intrigued with the size and the part I bolded the type face:
"The cabinet walls are all one inch thick and secured using proprietary techniques. The mouth of the system is part of an "S" shaped duct that divides the interior of the cabinet into three chambers. The bottom chamber, opening to the acoustic environment via the mouth, uses the floor as one of its walls."
I have been reading until I am bleary eyed on folded horns and TL designs and thought this must have some interesting "stuff" inside OR it could be hype. Is it a folded something?-- who knows, that is what I was looking for widom on.
I thought there was a lot coming from a such a small package...
The venue is a circa 1870 30'X 40' frame building with a 25' high peaked ceilingand th origianl wooden plank floors. The hope is to get down to 16 Hz with some autority and have it musical low distortion--tall order I know from my reaing thus far. We have 2 corners at the front where the sub(s) could reside.
I am a priest at a small parish north of Toronto Canada that appreciates the gifts of our young organist/musician and wish to support him. I also enjoy woodworking and have a limited budget hence the DIY endeavor.
The organ dealer nearby wishes to sell us 6000.00CAN worth of Definitive Technology speakers which he calims are the best in the world. Maybe you folk would have a comment on that stement!!!
Thanks for the 'venting" or would that be "porting" on this forum...I appreciate the hours of study and labours you folk have out in to turn out the great projects I read on these forms.
Fr. Ray
Old 13th July 2007, 04:19 PM   #10
Send a message via AIM to TwisterZ
You gotta love salesmen & politicians, God has a special place for them.
Yes I am a salesman and I have heard lots of DefTech speakers but to say they are the best in the world means this guy has listened to all the speakers in the world-NOT -
Enough ranting, sorry all
Fr Ray
How tall are you side walls? Pictures would help.
Looking for jazz bass and pipe organ toenail Music 8 16th January 2011 05:56 PM
DIY Home Pipe Organ ReidK Instruments and Amps 7 16th January 2011 05:43 PM
PVC Pipe speaker ideas chipco3434 Multi-Way 5 29th May 2009 05:36 AM
Pipe Organ sub workout Circlotron Music 3 10th April 2007 12:01 PM
seeking ideas for diy headshell (tonearm pics inside) percy Analogue Source 28 16th September 2006 10:40 AM
Page generated in 0.12497 seconds (88.42% PHP - 11.58% MySQL) with 10 queries
