Ideas as to what is inside? Need 16Hz for digital pipe organ-help?
Old 16th July 2007, 02:54 AM   #21
TwisterZ is offline TwisterZ  United States
Send a message via AIM to TwisterZ
Fr. Ray
I still can't get to your photos, here is my email spayette@aol.com. I would like to see what you are working with.
Steve
Old 16th July 2007, 04:02 PM   #22
Hello Fr. Ray
I got your email with the pics. I would still recommend the El-Pipe-O except use 4 of the Mach5 MJ18 woofers, they are much cheaper then the 21" woofers and will give you tons of bottom end. As I said earlier they would look like decorative columns in the right & left corners. Something like this
Old 16th July 2007, 04:08 PM   #23
AndrewT is online now AndrewT  Scotland
While we wouldn’t give you the t/s,
since they won't reveal the T/S parameters, then you can measure them. Since these measured numbers are your property, you can reveal as much as you like and they can't complain.
Any chance you could disguise the columns to look like the ones in the Rosslyn chapel?
regards Andrew T.
Old 16th July 2007, 05:10 PM   #24
Petriej is offline Petriej  United States
Be careful about which drivers you choose, you need one that can get as close as possible to 16Hz.
Also, since your side walls are 10ft high, I wonder if it would be possible to bend the tube to get the desired length (El Pipo is 14ft? at 20Hz so 16Hz would be considerably longer at ~half octave lower).
I haven't really had any experience with this sort of thing so maybe someone else can shed some more light on designing the enclosure.
Signature:
Optional signature you may use to appear at bottom of your signatures.
Old 16th July 2007, 05:44 PM   #25
Fr. Ray,
How wide is the Alter alcove and how high off the main floor?
Steve
Old 16th July 2007, 06:18 PM   #26
petriej
El-pipe-o is 12' tall according to the text and I would take a close look at the new Mach5 IXL-18.4 for a pipe style transmission line or acoustic wave canon. This is the speaker I want to use when I rebuild my canon.
Old 16th July 2007, 07:17 PM   #27
asiquis is offline asiquis  Canada
Interestingly I have been looking at the Mach 5 IXL 18.4 drivers.
Altar alcove is about 16'X16' (first step 8-9" high) and second step another 8-9" and the highest platform is about 16X 8.
Underneath is a crawl space.
A friend suggested the HouseWrecker sub from Decware
Supposedly goes to 13Hz if one builds the 18" version (just under 60 inches x just under 2 feet x almost 2 feet)
http://www.decware.com/newsite/mainmenu.htm
Old 16th July 2007, 10:31 PM   #28
If the crawl space goes all the way across and the steps stop at the alcove you could start with an Infinite Baffle on one side and if you needed more volume you could add a second one on the other side of the steps. This would have the greatest base without using any floor space. Here is a link to everything you would need to know about Infinite Baffle subs.
http://ibsubwoofers.proboards51.com/
Old 17th July 2007, 08:32 PM   #29
Putting it under the altar might not be a good idea. Can't have chalices and books vibrating off onto the floor, etc!
Just a thought
Signature:
Old 18th July 2007, 01:47 AM   #30
Might wake some of the folk up!
I had chatted with a couple of the folk re the column idea.
Might get away with laying them down. Remember the WAF--I have that times 15!!! No less than 15 wifes attend!!
IB looks very interesting need a little more research. There is a forced air gas funace under the altar but I dont know if that would cause a problem.
Tom from SVS subwoofers (sound) suggested a 28x28x44 (ish) box with 4 x12" long throw subwoofers the make of drivers and finer details he is determining with the LEAP PC at their facility
Will be making a decision shortly and thanks for all your support thus far, I know I will need you folk in the future!
Fr.Ray
Ideas as to what is inside? Need 16Hz for digital pipe organ-help?Hide this!Advertise here!
Looking for jazz bass and pipe organ toenail Music 8 16th January 2011 05:56 PM
DIY Home Pipe Organ ReidK Instruments and Amps 7 16th January 2011 05:43 PM
PVC Pipe speaker ideas chipco3434 Multi-Way 5 29th May 2009 05:36 AM
Pipe Organ sub workout Circlotron Music 3 10th April 2007 12:01 PM
seeking ideas for diy headshell (tonearm pics inside) percy Analogue Source 28 16th September 2006 10:40 AM
Copyright ©1999-2017 diyAudio
