Old 10th July 2007, 12:40 PM   #1
geminni is offline geminni  Yugoslavia
Default Eminence Delta 12LFA is 10 ohm nom?!
WinISD sometimes makes me wonder.... I have entered numerous speaker parameters and for some of them for "Znom" is 10 ohm, and some even 12ohm. Why is that? For those 12ohm is not so surprising for me, because those are some cheap chinese speakers but for Eminence Delta 12 LFA WinISD shows 10ohm. Here is the picture.
Old 10th July 2007, 04:37 PM   #2
Petriej is offline Petriej  United States
Ten Thousand Ohms??
I know I know.... I just had to.
Although it does seem out of the ordinary, I can't see why it would be a big problem, most amps don't care if its between 4 and 16ohms, right? (Maybe even higher?)
It does have pretty good SPL...
Maybe it is a misprint. Contact the MFG'er
Signature:
Optional signature you may use to appear at bottom of your signatures.
Old 11th July 2007, 06:49 AM   #3
It is not misprint because WinISD calculates Z nominal. I thought that Znom is 4 or 8 ohms because Z nominal is voice coils R dc and L mh.
I have been repairing some boxes where were cheep chinese speakers which had Rdc of 7,7 ohm to even 8,1 ohm!!! When you add the L from voice coil that shows at the end some 12ohm Z nominal.
So, if speaker is 10ohm nominal, or better to say has voice coil of 7,7 R dc, which is not common for 12" pa speaker with 10cm voice coil diameter, can it be made to be some 6,7 R dc,? When i replace that 7,7 with 6,7 orm in winISD then the SPL is higher
This is not for Eminence, this is some other speaker.
FE207E + Eminence Delta 12 LF larkinrulez Full Range 22 18th January 2009 05:28 PM
Eminence Delta B 8 inch driver BudP Multi-Way 1 29th April 2008 11:56 AM
FS : pair of Eminence Delta 10" ***LOWERED PRICE*** punk Swap Meet 1 12th July 2006 03:08 AM
FS : pair of Eminence Delta 10" woofers punk Swap Meet 0 9th July 2006 06:52 AM
Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application esaias Subwoofers 8 10th August 2005 05:17 AM
Page generated in 0.07528 seconds (70.61% PHP - 29.39% MySQL) with 11 queries
